Chris Ostlind
Previous Member
- Joined
- Sep 5, 2004
- Posts
- Reaction score
- 59
- Location
- South Bay
It's no secret that I think that the O'penBic kids sailing skiff is one heck of a cool little boat. I think the little Bic is one of the most interesting new boats on the market that could truly get young boys and girls out on the water to enjoy the whole wonderful thing about sailing. By energizing the youth, we'll have a much better chance of having energized teens and adults
So, I decided to draw-up a small skiff for kids of my own. One that a kid could build with his Dad in the garage at home. A boat that is economical to build, has the potential to return many hundreds of hours of enjoyment and most of all... will serve as a really great sail training craft where a child can learn all about the techniques of sailing.
The Cabrillo Skiff is very much patterned after the O'penBic with very similar dimensions. The sail area is just slightly bigger at 56 sq. ft. The sail is a very simple, battened, luff socked item that can be either Mylar, or in less finnicky Dacron.
The boat can be shoved in the back of any full sized pickup and with the tailgate down, will not stick out past the end of the gate. The mast is two piece, can be either filament wound glass (essentially, an economy windsurf stick) or, in much less expensive 6061T6 aluminum. The transom is wide open, so no bailing necessary. Once graphically painted and the sail decorated with vinyl transfers to match, this will be a real eye-catching hotrod for small dudes and dudesses.
This is a simple, stitch and glue boat with a watertight mast pocket and an interlocked internal grid for stiffness and deck support. The boat is built in 4mm marine ply with epoxy/glass laminates. Design displacement of the boat is 250 lbs. and I estimate the boat will weigh 75-80 lbs. all up. So, "kids" up to something around 150 lbs. will be able to use the boat. An example has not yet been built, but that will change in the next couple of months. I'm building the first one in my shop this winter. Should go quickly as there isn't much to it.
I'm going to be offering plans for $30 on Duckworks and they will be an instant download via a collection of .pdf files. Plans like this typically go for more, but I'm more interested in seeing lots of kids out on the water getting into sailing on their own boat, than I am in milking a few bucks out of the process.
Simple to build, very easy to sail and easily righted by a kid of ten years old. One string and one stick and the kid is off to join all his buddies on the water.
Chris Ostlind
Lunada Design
www.lunadadesign.com
Chris Ostlind
Lunada Design
