Old 02-05-2005, 03:10 PM
TonyHovis TonyHovis is offline
New Builder
Greetings from Belize.
I am a furniture builder for nearly twenty years.
A year ago I had the pleasure of watching Mr. Ted Moores build a couple of mahogany strip race canoes.
To make a long story short, my dreams of building a canoe, have erupted into building a much larger vessel.
All of my research seems to steer amatuers to ply and glass?
I am most definately an amatuer boat builder, though I dont feel like this will be my last one. Too early to tell. Suppose it is. Will i be happier long term with a more complex building method?
I am really excited about this, as is my lady. Any pearl of wisdom would be most appreciated.
Oh yes, the boat I want to build will be a 26-28' sail boat for weekends in the carib.
Thanks,
Tony
Old 02-05-2005, 04:43 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
http://media5.hypernet.com/cgi-bin/U...&f=2&submit=Go
Tony, the link is for the wooden boat forum. You will find a lot of help there and here. Start buying books on the subject and try to find a neighbor with experience to help guide you. Others on this forum and on the wooden boat forum will be better able to recommend the best books among the hundreds that are out there.
Skippy Skippy is offline
Rep: 12 Posts: 568
I haven't read it, but I've seen a reference to one book on materials:
Bruce Roberts-Goodson, Boatbuilding: Steel*Glass*Wood*Aluminum
"If you're deciding which material to use."
Old 02-22-2005, 03:31 AM
nero nero is offline
Rep: 112 Posts: 624
Buy a gallon of epoxy and silica powder, samples of glass fabrics, rip some of your pine scrap into strips of different sizes. Then have some fun building a model. You will learn a lot about what you will be doing when building a hull.
If you are a crafstman of 20 years, making a boat hull will be easy work ... only alot more of it. smile
Old 03-01-2005, 06:32 PM
Jim Herbert Jim Herbert is offline
Rep: 10 Posts: 11
First I would decide if you would be happier with a chined boat (plywood) or a round bottom (other methods). If you like round bottoms and your friends strip canoes, you might investigate cold molding with veneer and epoxy and glass.
Jim Herbert
Boat builder , tooling needed rudy Services & Employment 4 08-22-2005 07:47 PM
builder for Carolina style Hull gregorymacc Marketplace 6 06-21-2005 07:53 PM
Need Builder builder DShaw Boatbuilding 0 04-01-2005 07:31 AM
mold builder magnum Boat Design 2 01-01-2005 11:33 AM
Looking For A Boat Builder in Texas Cpt Albert Fiberglass and Composite Boat Building 0 11-01-2004 09:12 PM
