Old 11-02-2008, 08:10 AM
fearntechnology fearntechnology is offline
Rep: 10 Posts: 2
Nelp needed with boat ID
Hi All
Hope someone can help. I am in the process of buying this yacht but cannot identify it despite hours of research. She is 27 feet long and is rigged as a ketch or perhaps a yawl -yet to find the mizzen step!- she has a drop keel and perhaps had a doghouse fitted. An unusual feature is the offset companionway which I like. The only designs I have found which are similar are those by Phil Rhodes but none of them fit the bill 100%.
Any help would be greatly appreciated.
Old 11-04-2008, 08:33 PM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 203
Would need a better view of the cockpit, facing aft, to determine where the mizzen is stepped.
Old 11-05-2008, 06:35 AM
ironmatar ironmatar is offline
Rep: 36 Posts: 33
i can see a round spot in the middle of the aft bench? transom box in between what looks like wood trim pieces ...strange with that tall hand rail across the aft deck its seems like the mizzen boom would be way way up hi comparativly from what im familer with...in the process rendering the mizzn very minimal. im no expert but are you shure its a 2 masted rig?
IM
Old 11-05-2008, 03:12 PM
Rep: 10 Posts: 2
Hi Folks and thanks for the interest.
Yes there is definatley two masts, they are lying beside it. The mizzen sail is quite small, the gooseneck is high enough for the boom to clear the pushpit rail.
Will get some more details and photos tommorow if needed and post them up.
The hull is full of rain water and I have spotted that the keel is leaking outwards , so I may just write it off as too much work. You have to be prepared to walk away from a bargain sometimes.
Thanks again
Stephen T.
Old 11-08-2008, 11:04 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
Sensible man. Given the state of the used marketplace right now, you can get some amazing boats for very little money. Sad cases like this will consume money as fast as you can pump it in until your money well runs dry. Even free is not a bargain in many cases.
Old 11-13-2008, 01:50 PM
Sunset Chaser
Rep: 22 Posts: 203
"The only thing more expensive than a cheep sailboat, is a free one"
Some boats have keel plugs for drainage. Other times people drill a hole that can be filled in again later. Most often it's a leaky piece of junk and you're better off finding something else.
Help Needed with Boat Plans Benevolance Wooden Boat Building and Restoration 20 05-18-2008 05:16 PM
Boat molds needed A-white Boat Molds 1 01-07-2008 08:46 PM
Boat builder needed okikeokpoke Services & Employment 0 12-20-2007 12:01 PM
boat builder needed David Dewberry Boat Design 0 08-02-2006 06:33 PM
Boat Dock help needed evanrude Boatbuilding 13 06-06-2006 11:03 PM
