| Need a mast for Oyster SJ35 I am looking for a second hand mast for Oyster SJ35 with following specifications: I = 40.23 J = 11.84 P = 42.59 E = 16.06 The Bury is 5.6" The designed section lengths on the double spreader jumper strut rig are as follows: Height from datum (deck) in mm to vang tang( bottom ) = 180 to goosneck (top) = 1206 to lower shroud tangs = 4154 to lower spreader brkt = 4356 to check stay tang = 6550 to spinn sheave box = 7000 to intermediate shroud tang = 7560 to upper spreader brkt = 7787 to jumper tang = 9400 to cap shroud tang = 11281 to haliard exit box = 11436 to forestay tang = 11626 to runner tang (and jumper brkt) = 11715 to haliard exit box = 12050 to haliard exit box = 12300 to jumper tang = 13730 masthead = 14016 Spreaders raked aft 5 deg. lower spreader 900 ml length (brkt centre to shroud) upper spreader 660 ml length (brkt centre to shroud) Cross sectional dimensions: The mast is: 138/95 . It would appear that the taper takes place over the final 2700 The boom is 150/105 In addition this mast is keel stepped with 6 feet of it inside cabin, therefore total lengths required 15816 mm or 51.9 ft Would anyone be able to help me finding a mast for this boat. Thanks and best regards Petar |
| Aftmast rigs??? | jdardozzi | Sailboats | 489 | 02-11-2012 07:22 AM |
| Why does a cutter rig point higher & sail faster? | Rich Kinard | Sailboats | 140 | 08-20-2008 07:43 PM |
| Mounting a boom higher on the mast | Rehunter | Sailboats | 3 | 09-15-2005 09:02 AM |
| Melges 24 Carbon fiber mast | Carlito's | Sailboats | 0 | 09-14-2005 06:00 PM |
| Canting mast | casavecchia | Sailboats | 5 | 01-20-2005 12:15 PM |
