| Neat Singlehanded Keelboat from UK This seems like a very interesting boat: http://www.k1sailing.com/id1.html from the website: "The K1 is a 4.5m (15ft) high performance keelboat for single-handed sailing and racing. It combines a light, narrow hull with a 60kg bulb keel to create a fast, compact single-hander with the sailing qualities of a small keelboat. It is designed to sail heeled so that the bulb weight provides righting moment and hence contributes to sail carrying power and potential speed as well as reducing the likelihood of capsize. In gusts the stability of the K1 increases as it heels, ensuring a smooth sailing motion." Length 4.57m (15ft) Beam 1.22m (4ft) Hull weight 45kg (99lb) Keel weight 60kg (132lb) Sailing weight 125kg (275lb)+crew Sail area 11sqm (118.4 sq.ft.) Designer Paul Handley
__________________ yes, it is a revolution ---"So (yet) another new world begins." Andrew Hurst, editor of Seahorse magazine, August,2011 |
| That's a pretty boat, although I'm not sure it gains much from the weighted bulb on the daggerboard: it provides some righting moment but only when the boat heels. The picture in your post shows the boat sailing level and another picture on the web site shows the crew hiking out and providing perhaps 80% of the RM. The weight of the bulb would also make it harder to raise the centerboard (if that's the correct term when it is ballasted) to reduce tripping or death roll tendencies downwind IMHO. However it's a slick looking hull and seems reasonably priced for what looks like a quality product.
| It's counter-productive to add dead weight to a small boat, such as this one, unless you are also going to go for the benefits of a really skinny hull. Why add appendage drag and weight without going for a more efficient hullform? The skinny hull lifting bulb keel is a pretty neat idea as a counter point to all the potato chip performance dinghies out there already. |
| I have been waiting for someone to build a canter of about this size. Imagine a 15 to 18 foot boat with about 150 pounds in the bulb. You have block and tackle to cant the keel and don't need to worry about water-tight integrity, as it's a sealed dingy hull anyway. I would think a small planing canter would be a gigantic amount of FUN!!
__________________ ----- "Anything worth doing is worth doing to excess" |
| 18' canter Take a look at this... 18' Canting Keel Single/Doublehander
| K1 Apparently 30 of these have been sold since earlier this year. Note that the boat is designed to sail at an angle of heel and not flat like a "normal" dinghy. Here is a video and a fleet picture: http://www.youtube.com/watch?v=xDn4J...layer_embedded picture by Miles Handley/click on image:
| Perhaps the rotational inertia of the heavy daggerboard gives the crew more time to change sides?
| K1 Read what they say under "Faqs" on the website-the original url is dead-this is the new one: http://www.k1sailing.com/index.html This boat is designed to sail with an angle of heel-it is not designed to sail flat like an unballasted dinghy. It has semi-circular sections and a very narrow waterline beam for its length. click on image then again on resulting image:
| Neat Free Boat Plans For The Beginning Builder | Greenseas2 | Boat Design | 2 | 08-06-2009 06:44 PM |
| 14' Singlehanded Trimaran | Doug Lord | Multihulls | 19 | 07-28-2008 02:20 PM |
| singlehanded fast cruiser design, build | thefuture | Sailboats | 7 | 06-12-2008 03:28 PM |
| Singlehanded sail handling | Manie B | Boat Design | 5 | 06-02-2008 07:23 AM |
| Prototype Singlehanded Hydrofoil Catamaran | Doug Lord | Multihulls | 2 | 11-01-2006 08:02 AM |
