Moth on Foils- Bladerider vs Formula Board
Thanks Stephen!
----FROM THE BLADERIDER SITE SLIGHTLY EDITED:
The Bladerider Experiment
KA Ambassador Martin Love has spent many hours with KA chief designer Andrew McDougall perfecting the new designs for the 08 KA Formula.
What better way to test the allround performance of the Formula than against the X8 in a variety of conditions.
So the test pilots took to the water over a series of tests and here is what they found: 5-7 knots *--- The foiler "flys" when the average sailor can't get a Formula board to plane ( of course there will be exceptions , really light , fit guy's) *The foiler is blistering fast in these conditions .
7-8 - 12 knots --- *Upwind the foiler has much better VMG , Formula board can't point as high although marginally faster. *Formula board is faster downwind but on the lighter end of the wind scale can,t sail as low and can fall off the plane .
12-18 knots --- Upwind very even , Formula board faster but lower . VMG very similar. Formula board noticeably faster downwind .
18 knots + *--- The formula board starts to edge away now upwind and is considerably faster downwind. .
Conclusion ----- The foiler is amazingly efficient in light to moderate airs and will foil earlier than a Formula board will plane.
See the Bladerider in action
www.bladerider.com.au
© 1991-2006 KA Sail Australia Pty Ltd. All Rights Reserved.
Check out the pix:
KA Sail Australia - Bladerider v's Formula
http://www.kasail.com/windsurfing/news/12june07.html Changed:1:22 AM on Wednesday, June 13, 2007
