| more rudder questions I have recently bought a small (19'4") cruiser/racer and will set it up to cruise the Queensland coast. It has a reverse angled stern and an outboard mounted rudder which I want to change. What is/was the advantage of the foreward raked rudder? and transom? I want to make a verticle mount with a little balance and a kick-up blade because I just know I am going to bottom out somewhere sometime and don't want to tear the rudder off. ![]() |
| The keel is deeper than the rudder. If you need a kick-up one, the boat will be pounding on the bottom.
__________________ Gonzo |
| You could add a kick-up rudder with a little balance fairly simply but making the rudder vertical will triple the amount of work for very little gain. I don't see that angle as worth the hassle of straightening it. While it's always possible the rudder will hit- that keel seems like some fairly good protection. Have any others in your class made the changes you want to make?
Gonzo is right - you will be grinding your keel down before your rudder touches, so why bother? If you are looking for a shallow draft beachable reef-friendly boat, the fixed keel is going to be a problem. -- CutOnce |
| Proa Questions: Rudder/Daggerboard Placement | Inquisitor | Multihulls | 0 | 07-02-2010 11:23 AM |
| Rudder Construction Questions | SeaJay | Boatbuilding | 9 | 08-21-2008 10:09 PM |
| transom hung rudder questions? | sheboo | Metal Boat Building | 2 | 10-22-2006 06:47 AM |
| Rudder questions | John Stevens | Sailboats | 6 | 03-07-2006 01:02 PM |
| Rudder Questions | syko | Boat Design | 2 | 07-20-2005 05:47 PM |
