| Modern square-rigger? What would the rig of a modern square-rig look like, if designed for a reduced crew, but NOT a DynaRig? Would it be possible for in-spar sail furling on all masts? And what of stay sails? Would it be possible for them to be equipped with furlers, as most jibs are furled? A clipper of similar size to Maltese Falcon, but with a classic look to her? |
| semi=modern square rig S. S. Rabl did a square rig design the 1947 version of his book "Boat Building in your own Backyard." He put tracks on the yards and furled the sails to the mast. I couldn't tell you if it's designed for a reduced crew. I thnk he did it for the Sea Scouts so I suspect their was no shortage of deck hands. It looks like a fun design, but I'm not too sure of the practicality.
__________________ LP ---------- God bless the open minded people of the world. LP |
| Square Rigger, but not Dynarig I’m having little trouble figuring out what you want to accomplish by way of your original posting. Quote:
Is there an economic factor, or a complication factor in your question? Do you have a problem with the perceived cost and/or complication with the dynarig solution on Maltese Falcon, and you are looking for another solution(s)?? I do have in mind a vertical furling solution for the rectangular sails that could simplify the situation, and lower the cost to build. |
| Modern Aircraft Carrier | Dook | Boat Design | 105 | 10-20-2007 08:14 AM |
| Modern paddlewheels | Guest | Boat Design | 87 | 08-27-2007 04:29 AM |
| Modern Timber builds in Tr | lazeyjack | Wooden Boat Building and Restoration | 1 | 04-30-2007 01:06 AM |
| Modern Gunter rig | catsketcher | Sailboats | 4 | 12-24-2006 10:40 AM |
| Our Rigger Needs Help | sharkeymarine | Open Discussion: All Things Boats & Boating | 7 | 10-07-2002 07:43 PM |
