Modern Classic Sailboats
Discussion in 'Sailboats' started by Guillermo, Aug 1, 2014.
  1. Guillermo
    Likes: 191, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Hello boatdesign.net friends,
    I'm interested in gathering as much info as possible about modern classic sailboats' hull and appendages designs. I am focusing in long overhang, hanging rudder, bulbed keel, 12-15 m length boats.
    Any help will be much appreciated. Thanks in advance.
  2. Eric Sponberg
    Likes: 253, Points: 93, Legacy Rep: 2917
    Eric Sponberg Senior Member
    Hi Guillermo, Haven't seen you around here in awhile. May I suggest one of my designs that may fit your request, the Scandinavian Cruiser 40. You can see it on my website here:
    http://www.sponbergyachtdesign.com/SC40.htm
    This boat has not yet been built, unfortunately, a fallout of the worldwide recession. But its intent was to answer the very proposal you make.
    Some of the other boats we saw fitting this description are the following. Note that the first two have long stern overhangs, but plumb bows:
    CCYD 30 (Argentina)
    Wally Nano (Turkey)
    Morris 28 (USA)
    Spirit 46 (UK)
    Friendship 40 (USA)
    Hinckley DS42 (USA)
    Geranium (34', USA)
    Ginger (50', USA)
    If you can't find these through a Google search, I have some details on them I would be happy to send you.
    Long overhangs are the features that are the most definitive in your description--not too many people or companies make them.
    To what purpose are you collecting this information?
    Eric
    1 person likes this.
  3. philSweet
    Likes: 582, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
  4. Guillermo
    Thanks, Eric and Phil.
    Eric, I had already seen your beautiful SC40 when searching for information. Your pages are always an inspiration for me :)
    I have a prospective client who wants to design and build by himself a modern classic cruising boat, as a retirement project. He just wants my advice and the performing of some calculations along the process. Not my ideal involvement, but business is yet running very slowly over here.
    I will check the boats you suggest and be back to you if needed, thank you very much. I had also found this Med 40 design, which seems to be a good approximation to what is intended.
    http://www.sandemanyachtcompany.co.uk/details/349/Med-46-Modern-Classic-Sloop-2003/yacht-for-sale/
    I'll keep in touch.
    Best wishes.
  5. Ike
    Likes: 502, Points: 113, Legacy Rep: 1669
    Ike Senior Member
  6. CloudDiver
    Likes: 7, Points: 18, Legacy Rep: 40
    CloudDiver Senior Member
    For a bit of inspiration on Modern Classics, check out Spirit Yachts and Fairlie Yachts in the UK. Both are building jaw dropping modern classics with foil/bulb keels. There are several great videos to be seen on Youtube, especially a viedo construction diary for a Fairlie 55;
    http://www.youtube.com/watch?v=rDgKIPaW5xY
  7. JosephT
    Likes: 108, Points: 43, Legacy Rep: 218
    JosephT Senior Member
    My kind of yachts. Love the classic wooden sloops, brass & bronze hardware, etc.
  8. PAR
    Likes: 504, Points: 93, Legacy Rep: 3967
    PAR Yacht Designer/Builder
    I would think the W-Class an obvious choice.
  9. Guillermo
    Thanks a lot, Ike, CloudDiver and PAR. :)
  10. Guillermo
    Fairlies are beutiful, but oversized.
    I like these......although I find them more "daysailing" oriented than bluewater cruising boats, which is a requisite.
  11. rcnesneg
    Likes: 6, Points: 0, Legacy Rep: 58
    rcnesneg Senior Member
    This is a bit big, but it might give you some ideas. If it can be done with a J class, it can probably be done with a 12 meter and smaller boats with the long overhangs designed to similar rules.
    F class Firefly. Basically a J class with a fin/bulb keel and high aspect rudder.
    Here is their website.
  12. Guillermo
    After several meetings with the client, we have been finally commited to the design of a pure classic, inspired in the Concordia 39, forgetting about the spade keel + bulb.
    Thanks anyhow to all of you for your very kind help.
  13. Eric Sponberg
    Congratulations! Will you be designing in wood or perhaps in composite? Post pictures when the design is done and once the boat gets built.
    Eric
  14. Guillermo
    Strip planking + Cold molding, thanks a lot Eric.
  15. gonzo
    Likes: 2,092, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    Felicitaciones
