#31
| It is unfortunate that a post has been deleted from above. It looks to be an attempt to reorganize the history of the thread. No matter, as I have saved the essence of the post by Mr. Lord, along with my responses to his objections. Quote:
I prefer to avoid that sort of negatively personalized discussion in favor of other styles of communication. Quote:
Countless? Really? I suggest that the numbers of tinkered changes are very much countable and that the team members know of them with precision. If this reference is a routine exaggeration on your part, then it very clearly puts the rest of the comments in a much different light. Quote:
If the technique was originally created by someone else and Jundt copied the function, then he is not an innovator. He is a borrower and he joins the ranks of thousands of other boat designers who also borrowed good ideas, well before his efforts with this boat. If leaving off the more aerodynamic hull form is such a powerful tool for development, why then aren't more boats developed this way prior to having their hulls created? Why are there not dozens of Moths running around out there with space frame structures taking the place of their hulls. Moths are a development class and it would seem prudent to allow for the moving about of various elements in order to arrive at a better, more effective, boat. Strangely, we do not see Moths doing this. We also do not see this process by other boat designers as they work their way through the prototyping of their boats. Quote:
A Moth has an enclosed hull form which is a good deal more aerodynamic than this Swiss boat, even if the Moth were scaled to match the length of Mirabaud. For the percentage drag of the crew on Mirabaud to be higher than the suggested percentage drag on a Moth, the boat would have to be very aerodynamic in order to reduce its signature below that being generated by the crew of three. I think that perhaps you have postulated a reference in the exact opposite direction that exists in the real world. Yes, aero drag very clearly has a much lower priority in the Mirabaud camp and that is exactly what I said, "Instead, they have tinkered with incidentals while the elephant in the room goes plodding around, unnoticed." When a team completely drops the drag reduction process in favor of incidental issues, the resultant boat is not going to become a world beater by any metric you wish to apply. For a boat that is supposed to spend most of its time in the air, I am afraid that Mirabaud is a less than exciting example of aerodynamic efficiency. Quote:
A higher level, or just a different level? There is a difference between those two definitions. One could argue that this boat has not taken the art to any new level and that is supported by the fact that nobody else has bothered to produce one of their own. I would not call this boat a large bi-foiler and I do not believe that a truly large version of this type of boat can be made to sail effectively, even if someone built one. Again, nobody is emulating the form. Quote:
In your reply, you immediately go on the attack and personalize the comments you make, suggesting that I do more reading and spend some time reading the press releases. This position indicates that you wish to attack my opinion by suggesting that I am not informed, or have no true grasp of the situation and that you alone are the person capable of dispensing opinion. This is a less than admirable attempt to establish yourself as an authority, while disregarding the opinions of others. I suspect that it is not your job here to dispense orders for others to follow. I would appreciate it if you would stop. I think that there are ways to contribute to a conversation without making unnecessary comments, such as those put forth in your post. |
#32
The point is that since the foil forward arrangement had already been explored by another, it is impossible for you to make the claim that Jundt has innovated this arrangement. Whether he had previously seen the setup used by Bill Roberts is also of no consequence. It existed already and can not be referred to as an innovation. It can only be an adaptation and that fits with the vast majority of developments in boat design throughout history. Quote:
If that is your point, it was innacurately expressed initially and functionally meaningless as an arguing position until it is accurately expressed. Quote:
It's not out of line and remains so until you can produce proof of another craft of the type represented by Mirabaud and can show it to be actively used and tested in an on-going fashion. Failure to provide these proofs would indicate that your claims are out of line and unsupportable. The members here can decide if they are, preposterous, as you say. A built, sailed fitfully and scrapped, boat does not count Quote:
It looks as though your opinion will remain an eternal mystery since nobody is actively pursuing such a craft. There hasn't been a single proposal about anything even closely representing such a boat since the very briefly displayed concept illustrations from Bethwaite many years ago. It's a dead end with nothing to support the validity save for the conversations on these pages. Regarding the argument that the economy is preventing such a boat from being built; I would offer the new AC boats, the big, French ocean racing trimarans, as well as a half dozen other cutting edge multihulls, as examples that the economy has little to do with the large foiler exercise as proposed. I think the reason for no boat of this type is the fact that there are simply way too many technical obstacles to overcome to make such an endeavor worthwhile, when the target issues can be reached and exceeded far easier through other platforms that are much better understood. The very large cash outlay along with such huge development time is far too big a hill to climb for the likely very small return. |
| Mirabaud-Super Foiler! | Doug Lord | Sailboats | 30 | 10-12-2010 06:53 AM |
| 5-23-2010 Server Hardware Upgrade (now complete) | Jeff | Forum Questions and Suggestions | 7 | 06-01-2010 06:30 PM |
| Everglades Challenge 2010 | Doug Lord | Multihulls | 11 | 03-09-2010 02:58 PM |
| Jester Challenge 2010 | Manie B | Open Discussion: All Things Boats & Boating | 1 | 02-04-2010 12:46 PM |
| Top 100 Superyachts 2010 | ni-superyachts | Press Releases | 2 | 01-14-2010 03:49 AM |
