| MiniTransat laminate schedule Hi, Do you think it's possible to get some existing mini's laminate schedule? I would like to compare it to what I got from the calculations; for example, I got 15 mm of thickness of the bottom, made of solid glass.
__________________ "water always knows better" |
| 600g of carbon + 15mm of core + 500g of carbon is what they usually put on the best boats. not much, but it gets you on the other side
__________________ ____________ Nico |
| Nico, They are actually putting carbon on BOTH sides of the core these days? Amazing... ![]() Steve |
| and using fiberglass? |
how could I find the strenght of this laminate, so that I could get an equivalent solid glass laminate? Using the ISO rules, I've found 10 mm of thickness in the bottom.
| Itīs all about weight - You donīt crash these things ![]() |
| On these pages you can find a laminate schedule of the Finot/Conq Mini (although it's not the latest generation) for both versions using either glass or carbon fibre. Click on "Construction Amateur" and scroll down a bit. I guess "Zone 1" is the hull, "Zone 2" the deck and "Zone 3" is the superstructure.
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| Thanks Olav, I've checked the Finot website.. but I think Zone 1 is the hull (bottom and sides), Zone 2 is the bottom hull, and Zone 3 is maybe the centerline (keel line). Then there is the deck (Zone A) and the livet Zone B. I think I will go for a 6 mm solid glass for the hull, 9 mm for the centreline, and sandwich deck like this.
| Nemo, what laminate was assumed when the boat was drawn? I wouldn't want you to overbuild the boat and then be unable to race because it had too much freeboard. If it was designed with a really light laminate schedule, then that is what it will need to perform properly. If the weight increases, then the RM increases, so the rig must be stronger, and thus weigh more, so the hull must be .... You get the picture? ![]() Steve |
| Laminate schedule | jfblouin | Fiberglass and Composite Boat Building | 3 | 01-23-2005 01:39 PM |
| laminate design | Falcon | Fiberglass and Composite Boat Building | 1 | 12-09-2004 11:17 AM |
| laminate design | Falcon | Materials | 0 | 12-06-2004 01:24 PM |
| Laminate Schedule | SOB | Fiberglass and Composite Boat Building | 2 | 10-03-2004 07:22 PM |
| Laminate Layup | dlynch | Boat Design | 8 | 03-05-2004 05:42 AM |
