| Maybe a dumb question? I have a 17' Watkins sailboat. I am hoping to learn how to sail. Question: The mast has a forestay and two sidestays (right terminology?). It does not have a backstay, HOWEVER, it does have a rope (sheet?) that is fastened at the top of the mast to the aft and is long enought to reach the boom. Does this attach to the aft of the boom for support or is it intended to be a backstay? Told you it might be a dumb question. Thanx, sailortoo |
| From the way you have described it, I think that the line in question is the topping lift, which is there for supporting the boom when you lower the sail. It does attach to the after end of the boom, as you stated. |
| The stay on the forward side of the mast is called the headstay, the ones on the side are called shrouds. These shrouds are called the lower and the other is the upper (goes over a spreader in most cases) or is sometimes called a cap shroud. You could very well have a topping lift on you mast, it could also be the mainsail halyard or a spare halyard. If you have a mainsail halyard (line that lifts the mainsail up the mast) then use it as a topping lift. If your spreaders are angled aft a good bit then the shrouds may be taking the load, rather then having a fixed back stay. This is popular, so that a large roach mainsail can be used. Running backstays are also used on some boats. These need to be released at each tack an changed with the other side. This would be typical of racers or older style yachts. |
| Newby question regarding Epoxy and fiberglass redecking and plywood choices | baranx4 | Boatbuilding | 3 | 03-05-2007 08:55 AM |
| Stupid Question | McBoo | Open Discussion: All Things Boats & Boating | 29 | 12-27-2005 07:31 PM |
| Deck design question | forestjohnson | Fiberglass and Composite Boat Building | 8 | 12-22-2005 09:11 AM |
| Plywood question | bearwen | Wooden Boat Building and Restoration | 15 | 11-08-2005 04:43 PM |
| I'm reading Marchaj's 'Seaworthiness" and have a dumb question | BillyDoc | Boat Design | 9 | 06-28-2005 01:51 PM |
