Old 07-11-2006, 12:15 PM
Contraband Contraband is offline
Rep: 10 Posts: 4
Maximum Step Angle in a Sailboat
Hi everyone,
A very quick, hopefully simple question: From some references that I have I can get the minimum recomended tread depth for steps in a sailing boat, can anyone give me a reference, a suggestion or recomendation for the recomended angle for a set of steps in a sailing vessel, I am working on a catamaran, but I guess this angle is relatively generic. Any suggestions are appreciated and welcome!!
Regards
CB
Old 07-11-2006, 06:17 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 542
Contraband There is two definitions, stairs and ladders. Stairs are between 26degrees to 45degrees and the projected tread for stairs changes with the riser height with a minium riser of 150mm to max 220mm. For min tread use formula 45000/riser in mm and max 48000/riser in mm.
Ladders (step) should not be less than 60 degrees or more than 70.The projected treads should not be less than 100mm wide with a minimum distance of 150mm from the back. Riser height between 200mm and 250mm.
Rung-type ladders should not be less than 70degrees or more than 75, with rung spacing of not less than 250mm nor more than 300mm apart.
Hope this helps.
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 02:14 PM
Maximum radius for good water separation jfblouin Boat Design 0 10-31-2005 01:30 PM
What is the maximum deadrise angle? jfblouin Boat Design 3 09-20-2004 07:36 AM
Maximum beam ? Slowmo Sailboats 48 09-01-2004 01:03 PM
Plexiglass maximum radius curvature nico Boat Design 2 05-22-2003 02:03 AM
