| max -prop Hello Wonder if anybody can help me. I have a Yanmar GM30 with saildrive. I've just bought 16" max-prop. Does anybody know the correct pitch set up for this engine/prop configuration. Engine achieves 3600 rpm but I believe this drops to 3200 with saildrive leg fitted. I believe correct pitch is around 18 degrees but if anybody has the same set up and has experimented with different pitch settings I would welcome any advice that they could give me. Thanks. |
| I think it'd be whatever gives you the engine manufacturer's recommended RPM when the throttle is wide open. If you have a question about what this is you should contact a Yanmar factory technician. |
| Prop calculations | GeoffSChapman | Boat Design | 12 | 03-01-2005 03:26 PM |
| Offset single prop - which direction? | Ben Lindenberg | Propulsion | 7 | 11-10-2004 01:53 PM |
| sea ray prop for planing | jfc52 | Propulsion | 20 | 09-17-2004 09:09 PM |
| Ideal depth of prop/ surface peircing props | Sonnie00 | Powerboats | 2 | 08-01-2004 08:01 PM |
| Is this the right prop for this low speed inflatable? | bill fish | Powerboats | 0 | 07-30-2004 12:57 PM |
