| mast step and mast heel corrosion Code: damaging mast corrosion is most likely to occur at the heel of the mast. especially if it sits in a wet bilge area or if the step lacks an adequate drain. unfortunately the corrosion is likely to be on the inside of the mast what do you think about this one. do i need to lower the mast for the neccessary inspection? and what do you think about the corrosion at the mast step? cheers |
You can't see a lot of damaging corrosion - much of it is internal to the metal and it can manifest as crystalline metal degradation. Stress and repeated fatigue can be just as damaging as plain corrosion. -- Bill |
| No inspection necessary you can see there aren't any weep holes in the step and the step is steel, so you'll have corrosion, you can bet on it. |
| there are weep holes. i indicated them on the picture. cheers |
| Yep, I missed them, but still lots of corrosion present. |
| yes. But the mast base is steel, i think for steel it is normal. i wonder the condition of the aluminum mast heel. Can you make a comment about its condition? do you think that it has corrosion inside. cheers |
| If you remove the exit block you could reach a finger/shine a light inside. The screws look okay, but will probably be frozen. |
Do you never tire of being wrong? |
If you are concerned you can simply pull the rig and inspect. I would think you will have to pull the rig anyway to inspect and repaint the step. |
| thanks. this mast is belong to a old boat that i am planning tu buy. the rig had been change 10 years ago. but the mast is older. what is the lifespan of an aluminum mast? and what can you say about the surface condition of the mast? cheers |
| The live span would be damage and corrosion related on an aluminum mast. I've seen them several decades old, still in service. It looks like that one has seen some serious time at sea as well. Your best bet is to pull an inspection plate or other piece of hardware and have a good look underneath and inside the extrusion. This would only be a quick assessment, but possibly a good indication of it's condition. Select the oldest looking fitting to remove, as much of the bolt on stuff may have been replaced or moved 10 years ago when she was re-rigged or during her life time. |
| Mast Design and Heel Loads | navalarchwanabe | Boat Design | 29 | 11-12-2009 04:29 PM |
| Odd composite mast step..... | Roly | Sailboats | 0 | 02-23-2008 05:51 PM |
| Cracked Mast Step | James Moore | Boat Design | 12 | 07-29-2007 10:57 PM |
| Mast step repair | Rossair | Sailboats | 2 | 02-25-2007 11:15 PM |
| Mast step question | MikeR | Fiberglass and Composite Boat Building | 4 | 01-22-2007 09:23 PM |
