Old 08-08-2010, 04:22 PM
Roly Roly is offline
Rep: 222 Posts: 490
Mast step beam material
My mast step is required to bridge 4 floors @ 350mm cntrs
I propose to use two pieces 100x50x6mm Stainless steel channel welded together
to form 200x50mm with a plate welded to form the actual step.
I will cut the flanges down in an arc from 50mm to 20mm from the plate
(maststep) to the outer floor.
Working load compression 6tonnes upwind @30deg heel/ 20knots wind.
Is this an acceptable mast step- what do you think?
Perhaps I should extend the maststep top plate to the middle floors?
Overkill?
Seems to me that the outer two frames will only start loading if the middle two deflect.
Old 08-14-2010, 06:32 AM
Rep: 1729 Posts: 2,464
When your step spans four supports and is center loaded the outer spans have a reversed stress. You are trying to push the middle two floors down and push the outer two up. The beam should have the same section for it's full extent for it to work that way.
The other approach is to make it stiffer than the floor hull combination and load the 4 floors together. The design for that will depend on the rest of the structure, and not just the step support beam in isolation.
Mike Johns.
Old 08-14-2010, 07:39 PM
Rep: 222 Posts: 490
Thanks Mike.
Does that mean then, that the load is spread any more by spanning 4 floors instead of two?
The other scenario of calculating the stiffness of the hull through that region
would be an approximation as it is at the keel junction. (Steel & wood)
Old 08-19-2010, 07:55 AM
I sent you a PM.
I'd really need to see some drawings to comment properly but otherwise assume a reasonably stiff layup and design the step accordingly to load 4 floors.
Mike Johns.
mast step and mast heel corrosion urisvan Sailboats 10 11-23-2009 02:22 PM
Odd composite mast step..... Roly Sailboats 0 02-23-2008 04:51 PM
Cracked Mast Step James Moore Boat Design 12 07-29-2007 09:57 PM
Mast step repair Rossair Sailboats 2 02-25-2007 10:15 PM
Mast step question MikeR Fiberglass and Composite Boat Building 4 01-22-2007 08:23 PM
