Old 07-01-2003, 10:03 PM
ClarkT ClarkT is offline
Rep: 31 Posts: 103
Mast Splicing?
How effectively can a fractional rig mast that has broken at the jib hounds be spliced?
I know that a typical solution is to saw off the carnage, insert a sleeve, and thence to weld or epoxy and rivit. - This method creates a hard spot in the mast bend that would compromise sail performance.
It seems that a carbon topsection might be attached to the aluminum lower mast. The splice might be designed to maintain fair bending charactaristics, and the carbon topsection would lower CG.
Is this possible or cost effective?
Old 07-01-2003, 10:53 PM
Rep: 1493 Posts: 7,447
Can you weld the pieces?
Old 07-03-2003, 10:01 PM
Please note, aluminum welds are not as strong as the original material, unlike steel welds. A sleeve would be required, and it should be fastened by making a pattern of holes in the mast parts, and welding in the holes only.
Tim Dunn
Old 07-04-2003, 12:21 AM
That's the kind of weld I was refering to. If the sleeve has tapered ends it doesn't create as much of a hard spot.
Old 07-09-2003, 07:14 PM
Rep: 31 Posts: 103
I'm sure a carefully designed mast sleeve and a very good welder could make something that works, but how could I make an improvement on the original?
I had in mind to fabricate a new carbon topmast section, then machine the step of the new topsection to splice into the original aluminum mast. Since I'm already machining the step, I'll also machine a taper into the inside of the splice so the overall mast bend is still very fair.
Anyone have any experience with this sort of project?
Aftmast rigs??? jdardozzi Sailboats 492 03-22-2012 03:11 PM
Why does a cutter rig point higher & sail faster? Rich Kinard Sailboats 140 08-20-2008 06:43 PM
Mounting a boom higher on the mast Rehunter Sailboats 3 09-15-2005 08:02 AM
Melges 24 Carbon fiber mast Carlito's Sailboats 0 09-14-2005 05:00 PM
Canting mast casavecchia Sailboats 5 01-20-2005 11:15 AM
