Old 10-19-2002, 12:48 PM
stephan shugart stephan shugart is offline
Rep: 10 Posts: 7
Mast replacement
Does anyone have experience with changing from wood masts to alumuinum masts. Is it possible to change both masts in a ketch without tearing the whole boat apart. The displacemant of the boat is 26400lbs with a LWL of 30'4" and LOA of 37'4" with a sail area of 567 Sq. Ft. I'm not sure if when measuring sail area for a ketch that they include the mizzen. I would like to increase the sail area if possible. But don't I also need to replace the wooden part of the mast that goes down into the hull of the boat.
Old 10-19-2002, 05:40 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Yes, it is possible. You will have to modify the existing mast step to mount the aluminium mast base, possibly modify the deck/cabin roof opening to suit the different shape of the aluminium mast, and buy or create a new mast boot to keep the wet out. Presuming that you are keeping the same sailplan, you should be able to keep the rigging points on the hull the same.
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
Why does a cutter rig point higher & sail faster? Rich Kinard Sailboats 140 08-20-2008 07:43 PM
Mounting a boom higher on the mast Rehunter Sailboats 3 09-15-2005 09:02 AM
Melges 24 Carbon fiber mast Carlito's Sailboats 0 09-14-2005 06:00 PM
Canting mast casavecchia Sailboats 5 01-20-2005 12:15 PM
