Old 03-08-2004, 09:07 AM
Mast proportions
Hi. I'm designing a sailboat in Rhino for a "techlab" project at my high school. I've already designed the hull, keel, and rudder and now I'm moving onto the mast. I have a few questions about how to design it that I thought that people here might be able to answer (I've used this forum/site as a reference point throughout my project). My first question is what shape should the mast be? I'd rather not go with a plain circle, and I was thinking that maybe a modified ellipse would work well, but I wanted to ask. Also, if I'm making a mast that is 26' tall, how what should the mast dimensions be like in order to insure structural integrity. This is not exact, but I'd like to be at least somewhat realistic. If you need a material in order to make the decision, use carbon fiber. Thanks for your help.
Old 03-08-2004, 10:24 AM
Not A Guest Not A Guest is offline
Registered
Rep: 10 Posts: 55
A mast 26' long could be anywhere from 2" - 5" in diameter in wood.
Old 03-08-2004, 12:16 PM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Rigrite.com is the Kenyon Spars web site and has a wealth of info. including available spar sections and specifications. The Boat Data Book by Ian Nicolson is also a good reference for general specs. Good luck on your project.
Old 03-09-2004, 08:39 AM
Thanks for the help. I'll give those references a look.
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
Why does a cutter rig point higher & sail faster? Rich Kinard Sailboats 140 08-20-2008 07:43 PM
Mounting a boom higher on the mast Rehunter Sailboats 3 09-15-2005 09:02 AM
Melges 24 Carbon fiber mast Carlito's Sailboats 0 09-14-2005 06:00 PM
Canting mast casavecchia Sailboats 5 01-20-2005 12:15 PM
