Old 09-14-2006, 12:28 PM
EAP EAP is offline
Rep: 10 Posts: 9
mast loading for hull girder strength on a gaff rigged vessel
Thanks to all who replied to my post regarding the center of effort of a gaff rigged vessel. quite an interesting discussion resulted from that, from which I was able to get much input. I am now calculating the hull strength for my gaff rigged sloop. I need to calculate the estimated mast load resulting from sails, rigging, etc, such that I can find the maximum bending moment on the hull girder (waveloading notwithstanding, since my vessel will be a 20' lake sailor). Principles of Yacht design (Larsson & Eliasson) states that for a sloop rig: 85% of the vessel displacement would suffice. anybody care to comment and/or make recommondations??
Old 09-14-2006, 06:12 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Calculate for the maximum rightening moment.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 09-17-2006, 11:42 PM
ChrisF ChrisF is offline
Rep: 16 Posts: 37
Well...since what you want for longitudinal bending is the mast/forestay couple, not the mast/shrouds, max righting moment won't do it easily. Not without going through some sort of maxi-calculation where you calculate all the vectors from the sails to finally arrive at a forestay load.
On a 20-foot gaff rigged boat I wouldn't worry about it, unless the design is really unusual. Gaff rigs are typically not highly loaded, and small boats generally are plenty strong enough globally, just from being strong enough for local loading.
Old 10-02-2006, 06:35 PM
Duma Tau's Avatar
Duma Tau Duma Tau is offline
Rep: 12 Posts: 34
Low rigs make strong boats; gaff is about as low as it gets.
Step the mast from keel, through the deck ( if you have one) or a thwart.
Stays become almost optional from thereon.............
Sail a gaffer easy: let her pull through the wind with the boom out over the gunl, never centrelined like racing marconi rigs. No stress worries then!
Gaff rig is beautiful, good luck!
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 08:19 PM
ABS (bottom hull girder section modulus) Hisham Boat Design 24 06-11-2009 05:05 AM
researching this Gaff rigged cutter craigathome Sailboats 7 09-12-2006 09:42 AM
Spinnaker on a-class & hull strength/stiffness Martin Gibson Boat Design 7 03-17-2006 07:20 AM
Need info about a gaff-rigged cutter FranM Sailboats 0 04-09-2004 09:58 PM
