Old 06-28-2004, 06:11 AM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
making foils?
Hello all, any of you have any experience in making carbon foils?
Is prepreg suitable? What kind of weaves/knittings/tapes/rovings do you use?
Where to get it?
Old 06-28-2004, 11:51 AM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
I believe pre pregs to be the most suitable material as apart from being stronger/lighter it is also much more durable. The durability of the tips and edges is biggest let down of most foils.
www.fastacraft.com
Old 06-29-2004, 06:44 PM
Pompuous Pangolin
Rep: 43 Posts: 624
Thanks for the pointer,
how do you align the fibers, do you use only unidirectional? do you use some chordwise or at 45 deg to resist torsion?
Are you using two female molds, then bonding the two foil parts together?
Old 07-04-2004, 08:51 AM
mothingmiller mothingmiller is offline
Rep: 10 Posts: 3
hi,
i have reciently built hydrofoils using wet lay up, and although i agree that a pre preg foil is superior, there is a place for a wet lay up.
the way i manufactured the foil is described in a paper i wrote, and can be found at:
www.angelfire.com/retro/chrismiller
i would recomend you download the word version as the html version is a little screwed up.
the foils i have built are very stiff and plenty strong enough. the cost of the foil was abot £10 - £20. if you want more info about the lay up, or mold manufacturer just ask.
chris
Old 07-06-2004, 07:33 PM
Doug Lord
Foils: Fastacraft
Just got a set of foils for a special project I'm working on. They are the second set of hydrofoils I've gotten from John Ilett in Perth, Western Australia. Workmanship is excellent for these all carbon foils; I can't say enough about the quality and workmanship!
You might want to check out his offerings.....
Phil's Foils saildcat Sailboats 19 09-24-2005 04:04 PM
Twin Rotating Foils on Multihulls/No Daggerboard Doug Lord Sailboats 5 07-18-2005 11:30 AM
Why we dont control pitching with foils? xarax Sailboats 9 01-29-2005 06:30 AM
Techniques to make dinghy foils b_rodwell Fiberglass and Composite Boat Building 5 12-31-2004 10:31 PM
Moth on Foils Wins Aussie Nationals! Doug Lord Sailboats 12 02-21-2004 12:16 AM
