Old 09-01-2005, 01:42 PM
magelh magelh is offline
Rep: 10 Posts: 2
Low reynoldsnumber rudder
I am building a new rudder to my 2,4mR sailboat. It is my intention to try a deeper narrower profile than the old rudder.
Cordlength will be from 100mm to 190mm resulting in a rudder rarely exeeding
reynolds no. over 500.000.
Does anyone out there have any valid experience to share in this case?
Hasse
Old 09-01-2005, 03:45 PM
Rep: 1623 Posts: 1,483
Expect a slightly higher coefficient of lift at very small aoa, a lower maximum coefficient of lift, a higher coefficient of drag, and a much lower stall angle but a less dramatic stall effect. Things in real world situations get really iffy in this area (Rn 10^5 through 10^6) because of the laminar-turbulent seperation-attachment effects which really scatters the data.
Old 09-01-2005, 05:17 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Check out Mark Drela's X-Foil for work in this sort of reynolds number. It is known to be pretty good in air, and the last time I checked it against the CFD (in water) it was so good that I used it for all the low-angle-known-not-to-be-cavitating work.
However, it is written for low-speed applications in air, so it will not handle cavitaion. The trick is to work out the cavitaion Cp first, then the valid cases are those that do not exceed that Cp.
Best of luck,
Tim B.
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Rudder Design and Broaching joebobb Boat Design 0 02-25-2005 10:43 PM
Powerboat rudder design brooksie43 Boat Design 17 01-18-2005 09:52 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 04:36 PM
