Originally Posted by messabout ... I can put up a pretty stubborn argument against S&G builds if the boat is more involved than a flat bottomed skiff. I claim that the boat can be built faster and cleaner using conventional construction methods such as those described by Tom Hill and others. All that hole drilling and wiring and unwiring and panel layouts and wire hole filling are more time consuming than ... |
I agree. I helped a buddy make a S&G boat and it was a pain. Drilling, wiring, fiddling to get the planks to meet along the entire length of every chine was time consuming enough. Later there was the sanding down of what seemed to be rock-hard epoxy fillets with the dust and risk to lungs. Put me off that method of construction for good. Also it is a lot harder to fit bulkheads inside an existing hull than it is to bend planks around a bulkhead.
