| I am not sure what your intentions are but I think you would be better off using a true 3D model with the proper wind gradient and turbulence modeling and possibly sail flexing characteristics. Else you are guaranteed to have ??? about the validity of your findings based on 2D potential flow solution with thousand corrections you need to address the 3D, turbulence and sail/foil flex characteristics and the atmospheric wind gradient... Cem Last edited by albcem : 02-11-2009 at 01:33 PM. Reason: extra name |
| I would agree. The twist due to the apparent wind and velocity gradient varies significantly up the mast, even for upwind sailing. A wing mast angle of attack stays the same with height, but the sail segment behinds it naturally changes in twist with height. I think a 2D slice is too big a simplification...? |
| aerodynamic lift/drag ratio | PetterM | Powerboats | 1 | 04-15-2008 05:22 PM |
| Lift and drag theory | DSmith | Sailboats | 9 | 09-29-2006 01:34 PM |
| lift and drag changes at the onset of cavitation | boogie | Sailboats | 3 | 03-11-2006 12:58 AM |
| Drag/Lift ratios for beachcats | patrik111 | Sailboats | 0 | 04-02-2004 04:20 PM |
| Sail lift- and drag coeficients | Repelsteeltje | Sailboats | 1 | 07-13-2003 03:18 PM |
