Old 03-10-2010, 07:00 PM
Borneogoat Borneogoat is offline
Rep: 14 Posts: 5
Learning to sail a Balance Lug
I will be embarking on a boat building project soon. Although all my limited sailing experience has been on Bermudian sloops, I'm leaning towards a balance lug for this boat. The plans are made for it and from what I've read it sounds good for a 15' daysailor that will be used solo often. Although I've found much about the pro's & con's of balance lugs vs other sail plans, I haven't had much luck finding info on the basics of sailing a BL. When the big launch day comes (months & months away yet), it would be nice to have a clue of what I'm supposed to do! Don't have any friends with one, so hands-on learning might be limited.
Any suggestions on books, web-sites, etc?
Old 03-11-2010, 04:40 AM
Milan Milan is offline
Rep: 244 Posts: 319
John Leather's book Spritsails & lugsails.
Old 03-11-2010, 05:08 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,476
If you don't get the answer here, try www.woodenboat.com forum. You'll find some guys over there who use lugsails on regular basis - they will surely be able to give you some good hints.
Old 03-11-2010, 10:16 PM
aka Terry Haines
Rep: 1682 Posts: 2,816
Try googling "balanced lug rig"
It is one of the easiest rigs to handle.
Dances with Turkeys
Old 03-12-2010, 09:01 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
Time on the water!
Like most things, theory is great but practice is one hell of a lot better. Just do it.
It really helps if you develop simple metrics for measuring your progress - timing a known course etc. Seeing how changing rig setup affects actual Velocity Made Good (VMG) by comparing results to previous efforts makes a huge difference.
It really helps to log your settings and results so you can review things over time and see what works. The problem with theory is that your particular boat has it's own "sweet spot", and doing what works for someone else may not be the right thing for you.
Enjoy your boat and learn what makes it go fast the fun way. Turn off the computer and get on the water!
Bill
Old 03-12-2010, 01:39 PM
Rep: 1397 Posts: 7,215
They are OK. I have sailed plenty of small boats and canoes with them. You have a good and a bad tack. The bad being the one the sail lays on the mast.
Old 03-12-2010, 06:52 PM
Timothy Timothy is offline
Rep: 161 Posts: 166
Google Goat Island Skiff. There are instructions on how to tune a balanced lug.
Old 03-15-2010, 01:29 AM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
It should be no different than sailing a Bermudan rig. In fact it should be easier.
Check out to see a lot of boats rigged with that type of sail.
The Balance Lug is one of the two most popular sail types in the Puddle Duck fleet. It is runing neck and neck in popularity with the Bermuda like Leg-o-Mutton rig. The trick is to not have the boom and yard extend too far past the mast, and to have a hold down line attached to the boom right next to the mast to keep the boom from rising.
A lot of these sails were built by the skippers, who have never built a sail before, and used successfully, even though they have never sailed before.
...I never learned a thing from an argument I won...
Adding sail and maintaining the CE balance ecflyer Sailboats 3 09-09-2009 03:46 AM
flipping lug (lug nuts) Timothy Sailboats 3 05-09-2009 08:25 PM
New Balance Rig sail? Wellydeckhand Sailboats 3 04-29-2006 01:44 AM
Sail design - balanced lug Robert Miller Sailboats 9 11-30-2004 05:08 PM
Sail design and boat balance Archive Sailboats 1 06-21-2001 02:04 PM
