Old 08-28-2005, 05:10 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
lead in aluminium
If you put lead ballast in an aluminium keel, aren't you well on the way to making a battery? Add saltwater and something is going to errode. No?
Old 08-28-2005, 11:02 PM
Cian Groves Cian Groves is offline
Registered
Rep: 10 Posts: 31
Make your keel into part of your fuel tank and run fuel around it.
Cheers,
Cian
Old 08-29-2005, 09:18 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
People do that, and it seems to work OK, maybe because the top of the lead is covered with epoxy?
When we attach a lead bulb to an aluminium keel, we make sure there is a layer of epoxy between the two metal parts.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 09-03-2005, 08:04 AM
ted655's Avatar
Rep: 122 Posts: 641
Finally... back online. (hurricanes are a mighty force)
Actually, I want to "fill" a hollow keel space. Pouring in hot lead prevents any coatings between the 2 metals. After pouring, the top could be coated to stop contact with bilgewater.
Old 09-03-2005, 02:33 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
should be ok as long as it's kept dry everywhere (and that includes water seeming in from the outside of the keel.
Or you could turn it into a ballast-water tank... as long as you coat the inside with epoxy first.
Tim B.
Old 09-03-2005, 07:14 PM
ted655's Avatar
Rep: 122 Posts: 641
Thanks. This is a Sharpie flat btm. A cubic foot of water weighs around 9lbs, a cu.ft. of lead is 700lbs., I need the space so I can't afford the tank size.
I should be able to keep it dry if I epoxy the top.
Old 09-03-2005, 07:49 PM
Rep: 2891 Posts: 8,795
A cubic foot of water weighs a lot more then 9 pounds (you're thinking about a gallon). Try over 62+ for fresh and over 63+ for salt.
There are several methods for isolating dissimilar materials. It shouldn't be a big concern.
I wouldn't pour your lead in, but cast ballasting pigs of stackable and carryable sizes, that could nest in the keel. The lead will shrink when it cools and will likely cause wholesale plate distortion to boot. The pigs can be adjusted to trim out the boat during launch or if major changes take place (engine upgrade, etc.) These same liftable pigs can also lighten the boat by a substantial amount if stuck on the hard someplace far from a tow. Toss them over the side with a line and float. wiggle the lighter boat off and pick up your ballast again (it's cheaper then SeaTow) They can be fixed in place in a number of clever ways.
Old 09-03-2005, 10:06 PM
ted655's Avatar
Rep: 122 Posts: 641
Good advice all around! Thanks, I will do as you suggest. Duh! I was thinking gallons, and... I should have caught it. The displacement formula was my clue.
A fellow can't be handsom AND smart I guess.
Old 09-04-2005, 09:35 PM
I manage to struggle through some how. It's difficult being this handsome and smart too, but a burden I wear . . .
Old 09-05-2005, 07:32 PM
JimCooper JimCooper is offline
Rep: 10 Posts: 81
Ted
If you want the metal experts to give you advice you should probably post in the metal boats area. I found that the experts tend to inhabit only certain areas of this forum.
Your question was argued already by the knowledgeable laddies
see the box:
http://boatdesign.net/forums/showthr...ght=Aluminium&
I have been aboard an alloy trawler that a roll of copper pipe ate several holes in her hull. I think lead would do the same if it was in contact.
Cheers
Jim
Old 09-05-2005, 07:35 PM
Rep: 10 Posts: 81
Ted
I should hae said
That area to post is
Boat Design Forums > Construction > Boatbuilding > Metal Boat Building
cheers
Jim
Old 09-05-2005, 09:44 PM
ted655's Avatar
Rep: 122 Posts: 641
Does'nt sound like a method was settled on. I'm thinking lead shot, poured into suitable lengths of PVC pipe, then fit into place is the answer. these little 6"dia "logs" would fit nicely into the space and there would be no contact between metals.
Old 09-06-2005, 08:24 PM
Rep: 1623 Posts: 2,343
I just added an interesting observation to the thread/posts Jim refers to above.
Mike Johns.
Aluminium vs Steel Wynand N Boat Design 78 09-20-2007 08:34 AM
Keep Lead Ballast Clean John Allen Materials 7 03-25-2005 08:00 AM
Pictures of steel and aluminium small crafts? Cigra Metal Boat Building 7 03-09-2005 09:33 AM
Casting lead vabob7 Boat Design 0 03-08-2005 11:32 PM
Schooner Lead Bob A. Boat Design 11 01-23-2004 09:56 PM
