Old 09-18-2006, 12:36 PM
fmmarco fmmarco is offline
Rep: 10 Posts: 2
Lcg & Vcg
Hallo:
I`m looking for a method to estimate the LCG and the VCG of a modern 40' cruiser sailing yacht.
Someone knows a formulae, or same method for aproximate this values in preliminar stage of designing?
Thanks a lot,
Fmmarco
Old 09-18-2006, 12:43 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
If the boat is floating to its lines, then the LCG is , by definition, at the same position as the LCB. If you guessed wrong, though, the boat will never float to its lines.
Bottom line here is that there is no way to estimate it. Weights will be where the will be, and you just have to calculate it the old-fashioned way - by adding up the weights and centres, and designing a hull to fit.
Just one of the little hidden skills of design.
VCG? Same problem!
Steve
Old 09-19-2006, 01:18 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
SailDesign gave you a clue to LCG.
A very, very rough estimative of VCG, is around waterline.
But I agree with SailDesign: You should perform a weights estimative, fit lines to match and so on back and forth.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 09-19-2006, 07:34 PM
Rep: 1623 Posts: 2,343
fm marco
This seems to be a perrenial problem these days . You are designing a big boat with no idea whatsoever about the design spiral ? Is this a design just for learning or do you plan to build it?
Perhaps start with "How to design a boat" by John Teale it is a good gentle introduction for the newbie.
If you can get the numbers from a similar boat of the same construction it will be the best initial guide.
Cheers
Mike Johns.
LCG & LCB How far apart is acceptable? cvlngineer Boat Design 16 05-14-2006 10:33 PM
VCG\LCG Software Needed ETEE Software 2 10-04-2005 07:43 PM
Longitudinal Centre of Gravity (LCG) jileateta Boat Design 2 02-02-2005 11:06 AM
Help with LCG LCF and LCB!! fede Boat Design 20 02-27-2004 10:15 AM
LCG Centered or more aft? Sailboats 3 02-05-2002 05:07 AM
