Old 08-29-2011, 02:36 AM
BobBill's Avatar
BobBill BobBill is offline
Rep: 104 Posts: 379
Location: Minnesotan wakes up daily, a good start, snow or not, in Gingerville.
Laser/Force 5 ? on Sail Interchangeability for Kite Dinghy
Are the sails for these two classes able to be interchanged mast/spar-wise.
I understand the 5 spars are beefier and the mast is 3 sections, I have a set, but am thinking of trying a Hanson sail which has been designed and tested on Lasers (Hanson makes sails for boards) and has been quite impressive...
If it will fit the mast, why not?
Leave a place better. Congress is the enemy!
"All ya gotta know!" Dog. Winona.
Old 08-29-2011, 07:11 AM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
If you aren't class racing, why not? Bill Hansen should probably get a call, and he'd make sure the sail fit the spar - might cost a tiny bit more, but the end result would be a lot better possibly.
CutOnce
Old 08-29-2011, 07:46 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
BB, are you thinking of Hansens square top main for the Laser? In this application it might be pefect. Call Bill....
Last I knew Bills company was Hansen Aerosports but that doesn't come up anymore-this does: http://www.hansensails.com/AboutUs.htm last modified in 2006
picture: Hansen squaretop
yes, it is a revolution
Old 08-29-2011, 10:38 AM
BobBill's Avatar
Rep: 104 Posts: 379
Laser Force 5 Sail Interchangeability
Somewhat so, Doug. But it goes farther than just that...I have refurbished 73 Kite Class Dinghy, which is defunct as class but great wee boat.
They were made with nice wood spars. Over time, spars do fail, and I acquired a Force 5 rig and sail, just in case. Then I saw the Hanson Laser sail and got to thinking that might be the perfect fit. The sail is modern, simple and if it fits the 5 spars, I might have a fun alternative.
I tried emailing Hanson, and the site is down and in another forum, he said he is very busy with other issues.
No rush here. But if the sails are interchangeable, I can do some planning and some prep.
Old 08-29-2011, 11:30 AM
Doug Lord's Avatar
Flight Ready
BB-while Bill Hansen is very good there are many other sailmakers that could build you a squaretop matched to your spars. If you live close to one it would be worthwhile to talk to him/her.
Old 08-29-2011, 12:17 PM
BobBill's Avatar
Rep: 104 Posts: 379
I tried, and none compare to his experience and cost. He seems to have a natural instinct for exactly this kind of sail project that others do not posses. I guess his experience with board sailing is the reason.
Old 08-31-2011, 05:53 AM
BobBill's Avatar
Rep: 104 Posts: 379
Laser Mast Base Diameter?
Can some sailor supply the diameter of a standard Laser mast base?
Old 08-31-2011, 07:02 AM
Rep: 205 Posts: 470
63mm
CutOnce
Old 08-31-2011, 07:47 AM
BobBill's Avatar
Rep: 104 Posts: 379
Ahh, thanks. That translates to 2.5 inches and the Force 5 base at 2 3/8 inches...
Ergo, Laser sail sleeves will fit the 5 mast...sailing characteristics notwithstanding.
Merci.
Old 08-31-2011, 11:07 AM
BobBill's Avatar
Rep: 104 Posts: 379
Laser and Force 5 Sail Interchangeability for Kite Dinghy
Ah tooooo...it means the Hanson sail, shown in Doug's response above, will also fit the 5 spars.
Am ordering one as soon as I can get hold of Hanson.
That sail to add to the sails that power this little 73 dinghy...Cat Pause.
The original 73 McKibben is a bit stretched...altering a Intensity Force 5 to fit spruce mast and will use a Radial and the Hanson rig on the Force 5 spars when the need arises...
Am also making new rudder and considering a foil for it or dagger board...next year...if I make it.
Thanks for the help.
Old 08-31-2011, 11:24 AM
Rep: 205 Posts: 470
Merci.
Bienvenue et de rien. I'd also add/McGyver the updated Laser downhaul, outhaul & vang - you will need the increased purchase with the bigger rag. De-powering this rig will be an issue.
CutOnce
Old 08-31-2011, 12:20 PM
BobBill's Avatar
Rep: 104 Posts: 379
Yes, I thought of that...referring to the Hanson sail.
I was going to ask him to drop a top panel or if he had a slightly smaller version...
The Laser sails present little problem. Smaller than Kite sail by square meter or so...still, as always, the untried is unknown...
With the Laser sails, was going to use current downhaul, vang set and the Force 5 boom outhaul...for what I am doing, I think the down and out are overkill.
When sailing now I simply snug off the outhaul at the end of the boom and leave it, old sail no matter.
This little boat wants to leave the water when the breeze is 10 knots or more...and I tend to sail conservatively...at least for now.
Old 08-31-2011, 02:03 PM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
If his sail is well designed for the Laser mast it probably won't work too well with different spars... Much better to have the mast bend the sail is designed for. Just 'cos it fits, when it comes to the really sophisticated modern sails, doesn't mean it will work to best advantage.
Old 08-31-2011, 03:37 PM
Doug Lord's Avatar
Flight Ready
Most squaretops will have automatic gust response controllable with vang tension. Ask Bill Hansen about that with the spars you intend to use.......
Old 08-31-2011, 04:20 PM
Hansen Aerosprt's Avatar
Hansen Aerosprt Hansen Aerosprt is offline
Rep: 29 Posts: 62
BobBill:
For information on the Laser Turbo or Zuma Turbo sails, please email me at info@hansensails.com. We presently have both in stock.
Cheers!
- Bill
Laser as first sailboat. kroberts Sailboats 47 03-26-2011 11:58 AM
Force 5 Spar Question BobBill Sailboats 4 11-07-2010 11:08 AM
need help with laser tachometer bblagonic OnBoard Electronics & Controls 4 11-10-2009 03:21 AM
laser class gator51 Sailboats 6 09-28-2008 04:13 PM
Repairing a laser the_sphincter Fiberglass and Composite Boat Building 7 01-24-2006 07:14 AM
