Old 02-23-2011, 01:08 PM
kroberts's Avatar
kroberts kroberts is offline
Rep: 178 Posts: 282
Laser as first sailboat.
Hi,
I'm contemplating a Laser as a first sailboat. I don't have a specific one in mind, just beginning the decision process.
I've been on one which belongs to a friend of mine. I like it, I can sail it but there are definitely some things I need to learn. That's not what I'm asking about though, just giving background.
There are several things I would like to know:
  1. What do I need to look out for when buying?
  2. If something is missing or broken, how do I determine the price to fix it? How hard is it to find parts?
  3. The scupper on these boats seems to be a bad design. Is there a better one I can use that doesn't fit so poorly?
Questions about transport:
  1. I've seen a dolly that uses the centerboard hole to hold the axle. Is this a good idea or a bad one as far as boat strength?
  2. I'm going to car-top it. Right side up or upside down?
  3. Is it worth it to rout a support that follows the contour of either top or bottom of the hull (depending on the answer to the previous question), or will just foam or carpet do the trick?
Thanks.
-- Ken
No builds yet. Learning first!
Old 02-23-2011, 01:34 PM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Check the mast step carefully.
Old 02-23-2011, 02:33 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
A Laser is probably the best first sailboat anyone could own. Why?
You'll get out on the water and use it! It's so easy to maintain, beat on and bring to and from the water that you'll be excited and have fun any time you feel the wind pick up and decide to go sailing.
There is no substitute for that carefree sailing feeling which I no longer have with large boats.
As to really inspecting it... it's a Laser! Just buy it and beat the $O*% out of it. You'll have fun and learn a lot about sailing because Lasers are very unforgiving boats. A good amount of sail area for a small little hull you balance with your weight as ballast.
Get the hang of doing that and you'll build sailing skills that people who start on big boats never learn.
Go for it!
Old 02-23-2011, 03:46 PM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
Originally Posted by kroberts View Post
Hi,
There are many "buying a Laser discussions" on the Internet. Search the Dinghy Anarchy subforum on Sailing Anarchy for some really comprehensive answers. All your questions have been asked and answered.
Thanks.
Flat side down is easier on the important side of the boat. High density foam at all contact points works fine. Don't rachet down tie straps to the point where you get deformation of the hull. Always protect your hull bottom.
CutOnce
Old 02-23-2011, 04:03 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
Laser
Here is the Fleet directory for District 20 including the Chicago area. Contact your local fleet for help. http://d20.laserforum.org/
Click on "Fleet Directory" for the guys closest to you....
Also:
http://ezinearticles.com/?Tips-For-B...ghy&id=4153779
http://www.lasertrader.org/
Here's a short article ( http://hubpages.com/hub/Laser-Dinghy...-Sailing-Dingy ) :
Laser Dinghy For Sale - Tips When Buying a Laser Dinghy
Lasers are popular because they are so versitile, but this popularity also gives them a dangerous quality. Different companies all over the world are popping up promising that they are selling a 'laser' dinghy. Some of these are valid claims, but most are not. You need to be equipped with the right information, therefore, before you purchase a laser dinghy. Know the specs, and the history - which have been noted above - but also take advantage of the tips I will list below. The economy is poor as it is - you don't need to waste any more money into it.
First thing first. Make sure your Laser dingy is actually a laser sailing dinghy. Every official laser will have a sailboat sail number inscribed into the deck, or - if it's newer - in the back of the cockpit. Numbers that are less that 148199 will be in the deck and everything above will be in the cockpit; keep this mind when checking the authenticity of the dinghy boat, as well as age and quality.
Next thing you should do is inspect the physical ability of the boat; it's like checking the odometer of the car, sort to speak. There is no odometer on a sailboat, however, so you have to be a bit more ingenious. The general rule of the thumb for the deck is is if it has a lot of give - meaning it's not very stiff - then its had a lot of use. Check the give of the main areas of the boat - the front of the boat, and the cockpit are the most important - to gauge the quality and age. Also check for cracks. If there are a lot of cracks on the hull or deck this means that there has likely been leaking and damage; this will tell you that the boat has had a lot of use, and that - coupled with the amount of give - should tell you the overall quality of the dinghy.
Next check the sail for any serious signs of wear and tear. A new sail with a crisp feel to it; it may even feel a little stiff. As a sail is used it will lose it's stiffness, acquire creases, and maybe even a few small rips. A good sail is vital in having a good laser dinghy. Also note what kind of sail it is and if it can be made bigger or smaller depending on what kind laser rig you choose to you.
Another vital part of your laser dinghy is the mast and boom - also known as the Spars. These are both made from aluminum and can be easily bent; bent Spars is a common occurrence from everyday sailing, but - and this is a big but - they should be able to be bent back afterwards. If it is permanently bent you may want to think twice about the dinghy boat you are looking at.
The fact is is that laser dinghies are small and robust and can handle a lot of wear and tear; but, like all things, there is a limit. Be sure to check everything on your laser dinghy - don't let any nook or cranny go unchecked and take great detail of any cracks, give of the hull, or anything else out of place. You have to be your own personal, portable, odometer; make sure you know what your buying before you get out onto the water.
yes, it is a revolution
Old 02-23-2011, 04:07 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
This is so true. Big boats are also a big responsability. Small dinghies are pure fun!
Old 02-23-2011, 11:38 PM
Rep: 3125 Posts: 9,408
You guys have never owned a Santa Cruz 50 . . .
Old 02-24-2011, 12:26 AM
kroberts's Avatar
Rep: 178 Posts: 282
Thanks, I found a FAQ on laserforums.org.
I noticed that a laser 2 can have a jib and spinnaker too, and a trapeze. Can you do this on a laser 1? I'm asking because I think it would extend the useful lifespan of the boat to me, it would be a shame to get bored with it after I get better at sailing.
That all said, I still have a hankering for a boat not quite like what everyone else has. It would be neat to have a boat which could race in the same class as a laser but be an obviously wooden boat.
@PAR: That's my OTHER boat.
-- Ken
Old 02-24-2011, 10:32 AM
Rep: 205 Posts: 470
Officially and practically you can not. Once you change a Laser in any permanent way, it is no longer a Laser. Dinghies have quite extensive class rules defining exactly what the boat is, exactly what latitude you have in it's rigging and configuration etc. Lasers are VERY strict about this. That being said, some very demented individuals have "frankenboated" Lasers to add spinnakers, stays and trapezes. Search for Frankenboat.
You aren't going to lose money on a used Laser buy, so buy one, sail it for a couple years and you'll be able to sell it without losing a dime. Then go buy something else.
There is NO wooden option if you are sailing a Laser. There are lots of wooden options (especially if you look towards Australia), but they can't sail as a Laser. The Farr 3.7 comes to mind, as does the Sabre.
Just go buy one off Craigslist or Kijiji and start sailing now. Don't pay too much and follow the Laserforum (or Dinghy Anarchy) guidelines. On Dinghy Anarchy look for posts by "Gouvernail" - he's a former Laser Class President in the US and crusty, but absolutely encyclopedic in his Laser knowledge.
BTW, Gouvernail means Rudder in French.
CutOnce
Old 02-24-2011, 11:08 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
If you want a wooden "Laser", you'll likely have to build one.
What a great project!
You may want to buy a real one in the mean time, then sell it when yours is ready to fly.
-Tom
Old 02-24-2011, 11:19 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Laser, easy to sail, difficult to sail well. What can I tell you???
http://en.wikipedia.org/wiki/Death_roll
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 02-24-2011, 02:02 PM
Rep: 670 Posts: 2,457
Hmmm...many questions ???? Hard to answer in a paragraph. . Lasers are lightly built sport boats. Great, Fun boats !! , and just like thousands...perhaps millions of sailors before you.... you will learn much about high performance boats and fast sailing ....but Lasers show age rapidly.
As was pointed out...mast steps wear fast.....hulls and cockpits go soft.... centerboard trunks are easily damaged....
I suggest you go for it and have fun......but drive a hard bargain ...avoid paying premium for a Laser
Old 02-24-2011, 02:44 PM
kroberts's Avatar
Rep: 178 Posts: 282
Interesting.
I always thought the death roll was the one sitting under the heat lamp so long the frosting bubbled down onto the tray, and the cinnamon and bread cooked into a semi-petrified chewy mass likely to come out in approximately the same condition it went in.
I guess there are two things going on in my head.
First, it would be nice to have a racing boat that can compete with near Chicago. Lots of lasers on the lake.
Second, it would be nice to have a wood boat finished clear so it looks like wood, that I can take an insanely soggy and wiggly rottweiler on. I like the looks of an Alexa's Rocket AR15 with the wet deck. I also like a Core Sound 17 or 20. That gorgeous one they have in the pics (CS17) with the hand made pulleys and all that, wow!
So, ideally, I would have a 1-2 seat wooden racer with a wet deck that can take a jib and spinnaker (and trapeze and wet dog) should I ever get good enough to handle them.
Looks like my first boat may be a laser.
Thanks for all the input guys, keep it coming if you have something to add!
-- Ken
Old 02-24-2011, 03:09 PM
If you would like to sail in regattas, its important to have a bunch of mates to sail with.
If the local gang all have Lasers...get a Laser !!!! If the local boys all sail old rubber tires..GET AN OLD RUBBER TIRE !!!!!!!
Sailing is best when you can do it with a bunch of mates...then hit the shore for cold beer and sea stories.
Old 02-24-2011, 03:10 PM
Doug Lord's Avatar
Flight Ready
Since you're willing to consider a larger boat but seem to like the one design nature of the Laser, why don't you consider a Lighning? Large fleet in Chicago
and used boats available for 500 on up. Great bunch of people who would gladly get you into one before you put any money down. This is a boat that would allow daysailing and racing and would allow you to grow into spinnaker sailing.
used boats: http://www.lightningclass.org/market...ieds/boats.asp
The Chicago fleet: http://www.corinthian.org/lightning/
Laser as first sailboat.-lightning.jpg  Laser as first sailboat.-lightning-cockpit.jpg  Laser as first sailboat.-lightning-upwind.jpg
Hull delamination on a Laser. kroberts Boat Design 15 07-20-2010 12:55 PM
3d model of a Laser Sailboat tatria Boat Design 4 04-12-2010 09:10 AM
need help with laser tachometer bblagonic OnBoard Electronics & Controls 4 11-10-2009 03:21 AM
laser class gator51 Sailboats 6 09-28-2008 04:13 PM
Repairing a laser the_sphincter Fiberglass and Composite Boat Building 7 01-24-2006 07:14 AM
