Old 08-24-2008, 02:14 AM
gator51 gator51 is offline
Rep: 10 Posts: 3
laser class
I want to build a laser class sailboat,does any know where i can get plans
thanks
Old 08-24-2008, 02:43 AM
mr curious's Avatar
mr curious mr curious is offline
gunkholer supreme
Rep: 20 Posts: 94
http://www.brucekirbymarine.com/laser.html
maybe...
Old 08-24-2008, 11:35 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
thanks
The Laser is a highly regulated one design class with authorized manufacturers. You can not build one from plans - it would not be accepted as a Laser. There are many alternatives to the Laser of similar size, performance and capability, but the Laser is not possible as a self build.
If you wished, you could take off offsets from a Laser hull and build a Laser-like boat using the same rigging, but it would not be a Laser.
Old 08-24-2008, 02:37 PM
pulsar pulsar is offline
Mechanical engineer
Rep: 30 Posts: 32
I have found model of laser on www.delftship.net (in design database). It's only shape of hull.
Old 09-27-2008, 03:54 PM
mat82 mat82 is offline
Rep: 10 Posts: 2
Patented ones??
Hello do you know the US patent numbers of the Laser sailboats? I have found the 5163377, but i'm not sure, the model displayed on it has a long keel wich seems to be part of the hull...
Thanks!
Matías
Old 09-27-2008, 11:33 PM
Rep: 2891 Posts: 8,795
I'm not sure what boat you're referring to, but the Laser is a centerboard dinghy and doesn't have a long keel, or a noticeable keel of any kind. It must be another boat.
Old 09-28-2008, 05:13 PM
Rep: 10 Posts: 2
You are right PAR, the 5163377 is from another sailboat designed by Bruce Kirby. I've found another, the 304922 in the attached image I think it might be.
I've looked too other Lasers descriptions (Radial, 4.7, M, and Rooster) and photographs, do you know the differences between them and the standar?
Thanks!
B.regards
Matías
3d model of a Laser Sailboat tatria Boat Design 4 04-12-2010 10:10 AM
Maths Model of Laser dbharrison1 General Computing 0 05-30-2008 12:48 PM
Maths Model of Laser dbharrison1 Boat Design 0 05-28-2008 07:43 AM
Repairing a laser the_sphincter Fiberglass and Composite Boat Building 7 01-24-2006 08:14 AM
Need LASER 1 3D model for my thesis Tomas atria Boat Design 0 02-06-2004 01:43 PM
