  #31
Old 08-18-2009, 09:59 AM
wardd wardd is offline
Rep: 132 Posts: 254
originally was the keel cast with the bolts in place?
  #32
Old 08-18-2009, 01:01 PM
lat 64's Avatar
lat 64 lat 64 is offline
Rep: 10 Posts: 14
I am thinking now perhaps I need to pull a stud to confirm the thread size and if they are machine threads in good shape, then I should just replace the studs with some made of a good material. Confidents in the existing design was most of my concern, but I am getting the picture that this method was customary. It did last this long.
but if they are self tapping lags, could they be messed up when I pull the studs? I wonder if I should go to machine threads if this is the case.
Gilbert is right; I should not be imagining a problem if there is not one.
You guys are making me think twice about this tapping in lead stuff. That's a good thing of course.
Ward, Probably not. The drawing in my owners manual has notes to drill and tap. I wish I had the detail dwg that it refers to.
See attached,
Russ
PS. Gilbert I took a look at your gallery. I like those little italian boats too. My avatar pic was taken on the beach in Monteroso in the Cinque Terr(sp?) saw some boats there.
  #33
Old 08-19-2009, 04:32 AM
Rep: 1133 Posts: 4,718
Nope, they're not machine threads they are really hanger bolts as I originally thought. This assumes the drawing you've attached is the same as what you have.
Remove one hanger bolt. You can try and use a double nut arrangement, but I'd prefer to use an inserter so you don't stretch or tear up the threads.
Lags aren't tapped, just machine threads.
  #34
Old 08-24-2009, 11:36 PM
lat 64's Avatar
Rep: 10 Posts: 14
last post
Thanks all for responding to this thread.
I am much more informed about this and confident of the outcome now.
I will not get to the keel bolts until spring. This project just needs more real data(what is it I have anyway?) I must pull a bolt this winter.
I just found a 3/4 inch heavy-duty drill on a portable-drill-press thingy from a junk shop that will come in service for the hangar stud replacement. The thing is a beast from the fifties or sixties, with gobs of torque and a johnson rod to pull it into the work or keep it from feeding too fast.
Yeee ha, Gonna drill me some HOLES!
Russ
First Time skbayfish Open Discussion 0 04-28-2008 02:10 PM
Ok, its time has come dem45133 Motorsailers 19 10-10-2007 08:04 PM
Time... Sean Herron Open Discussion 7 05-06-2007 09:27 AM
Keel Time ;) AleX`G Sailboats 1 03-27-2007 11:02 PM
Decision Time Wynand N Boat Design 8 01-26-2005 05:51 PM
