Old 10-01-2003, 03:04 PM
Hannu Rantala Hannu Rantala is offline
Rep: 10 Posts: 16
That's true...why is the lead measured then as a percentage of DWL. As a percentage of CE height it would tell us more.
Perhaps because it is clear parallel line with lead?
Old 10-01-2003, 03:58 PM
Rep: 1397 Posts: 7,215
The depth of keel also affects the offset. A deeper keel has a larger movement to windward than a shallow keel.
Old 10-01-2003, 08:16 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
I originally advocated using heeling arm, Gonzo, but I'm not sure the center of drag through the water moves to windward much as the boat heels, and that's the real issue. It might on a narrow boat with a very large ballast bulb, such as an IACC boat, but the additional stability from that bulb will likely mean a taller rig, so I think measuring from the waterline still works in that case. Either way the reasoning would be more valid than using a percentage of waterline length. If it were then determined that other factors prevent all boats from clustering together we could do some interesting and meaningful analysis.
Fixing lead filled sheet metal keel with internal corrosion DennisRB Sailboats 2 08-02-2005 03:01 AM
Casting lead vabob7 Boat Design 0 03-08-2005 11:32 PM
Schooner Lead Bob A. Boat Design 11 01-23-2004 09:56 PM
Does the use of lead shot devalue a boat austerberry Boat Design 2 04-14-2003 08:53 AM
converting sloop to ketch? tim mcd Boat Design 4 02-22-2002 04:43 PM
