Old 03-27-2007, 05:24 PM
AleX`G AleX`G is offline
Rep: 22 Posts: 68
Keel Time ;)
Hey guys
As some of you may know i have been making a model rc boat at school during my lunch break. We are almost at a stage where the hull is finished. I want to decide on a keel that i can use and make which will suit the yacht best.
The main problem is the limited depth of keel to just 30cm from the deck. This is on a 2kg boat with 70cm length and 2000cm^2 of sail.
The freeboard of the boat is about 6cm so this leaves 20-24cm for me to play with for the keel.
The balast can be upto 55% of the total weight so thats 1.1kg
What kind of keel would you guys recomend. A normal single fin or something more elaborate I like the sound of the V keel but unsure how easy it would be to manufacture on a scale this small.
Is it possible to buy wing shaped tubing that i could bend to shape perhaps?
Alex
Old 03-27-2007, 11:02 PM
RichR RichR is offline
Rep: 10 Posts: 11
I used to do a bit of RC 1meter class and alot of the home build projects used bulb keels.
check out http://www.mya-uk.org.uk/scotland/Classes/classes.htm
Keel strut and keel trunk construction brevell Fiberglass and Composite Boat Building 0 11-20-2006 12:01 PM
Converting Shoal Keel to Centerboard-Keel mcollins07 Sailboats 4 06-29-2006 06:22 AM
Fin Keel to Lifting Keel on my Columbia 28 SteveWinNH Sailboats 5 04-05-2006 06:35 AM
time to replace the iron keel with lead but... tranmkp Sailboats 2 02-08-2005 04:28 PM
Keel Foils (optimizing a 70's keel) ErikG Sailboats 9 06-28-2004 10:58 PM
