Old 02-14-2010, 08:17 PM
Panos_na's Avatar
Panos_na Panos_na is offline
Yacht designer - Student
Rep: 10 Posts: 60
Keel and mast position
Hi there!
I am dealing with a sailboat design and I have designed the hull.
Now I want to move to the next step. According to some books now I have to deal with the keel and rudder design.
As known, the horizontal distance between the Centre of Lateral Resistance of the underwater body (CLR) and the Centre of Effort of the sails (CE) is very important for the balance of the boat.
I have found some methods to calculate those two, but I dont know how to start.
Should I put the keel at a longitudinal position, having in mind similar boats? Or is there a thumb of rule that I can follow?
Old 02-15-2010, 01:47 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
For initial design you could use the following:
*Keel center of effort (not center of area!) is ~22% from leading edge, ~45% down from the hull bottom
*This COE has to be at 45%, +/- 2% aft from fore end of LWL.
Then appropriate method for placing the rig relative to keel COE, or center of underwater area, or whatever, could be used.
By "appropriate" I mean method, developed for (or derived from) boats of similar general architecture: type keel and rudder, hull form and proportions, type of rig.
For example, several methods I know have to be used completely differently for masthead rig and 3/4 rig.
As you do not mention weight balance and trim problem I assume that weight calculation is done, and you know how much ballast and what longitudinal position is required.
Regards.
All the stresses in my designs are 95% of permissible.
Old 02-15-2010, 04:38 AM
capt vimes's Avatar
capt vimes capt vimes is offline
Rep: 185 Posts: 229
seems to me he hasn't done it yet... otherwise he would know the CG of his design and therfore the position of keel and mast...
panos:
if you have the hull you know the CB at 0° heel... CG has to be inline (longitudinal) with your CB... take your layout and calculate your CG... that will give you an approximate keel (knowing your displ./ballast ratio) and mast position... compute your max RM which will give you your max sail area the vessel can carry... calculate CE for lateral plan and sails... it will give you the lead and position for the mast in relation to your keel and therefore the lead... redo your CG calculation and start again from there...
that's at least the way i understood the design process of a sailing yacht...
Old 02-15-2010, 09:24 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
This can be a complicated question depending on the design of the hull and keel, and the sails.
If you are designing a conventional hull with a rudder on the trailing edge of the keel, with conventional marconi type sail rig, most designers simply balance the centroid of the projected areas as an approximation. And than they plan on doing fine tuning once the boat is in the water with mast sweep and sail adjustments. this is the most common method used by far.
Modern high performance sails with deep bulb keels, spade rudder, and with a constant foil section keel will be something different again. There is no easy method for exact results with modern hull and sail designs.
Perhaps if you give more details of your design, size, hull type, etc. or even drawings someone can suggest a method.
What part of Greece are you from?
Deck vs. keel stepped mast on HR 34 bluski Sailboats 1 11-16-2008 01:45 PM
Keel Position thealliance Boat Design 11 02-13-2007 01:45 AM
Centre of effort and keel position. AleX`G Sailboats 6 08-06-2006 09:20 AM
Canting Keel and Mast on a mini 6.50 nick cutter Sailboats 4 04-19-2006 03:32 AM
Mast/centreboard position/size Peter Rhodes Sailboats 4 06-05-2005 11:15 PM
