| keel Lift vs side Force help??? I'm trying to calculate the area needed for a keel for a 60 foot yacht. My sail plan give a side force of 9312 N at a Apparent wind angle of 27º and a wind speed of 9.5m/s, so if I'm not wrong I'm looking for a keel that makes a lift of a 9312 N at a yaw angle about 5º. The thing is that I'm getting very low Lift values for my keel The data I'm using is: Tk 1,7 Chord Top C1 2 Chord Bottom C2 1,5 Sweep Angle 21 AR keel 0,971428571 Main Chord Keel 1,75 Taper Ratio λ 0,75 Area Keel 2,975 CL 2d foil 0,11 α degrees keel 5 CL Keel 0,179807692 CDI 0,010593898 And getting those lift and drag values, but those are not large enogh, and the keel is quite large already, and the sction is a naca 63A012 Drag 186,7417686 Lift 3169,523279 What I'm doing wrong.... Thanks |
| 63A012 and AOA=5 degrees? Offhand, I think you are out of the drag bucket. Try it with a NACA 0012. remember that low drag is not equal to high lift. |
| Theoretically the lift formula should be L= 1/2*Cl* p*S*V^2 Where p is density And the Cl obtained from: Cl= Cl2d*α/(1+(2/AR)) AR=Tk/C where Tk is draft and C is chord but .... which Tk should I consider, the depth from bottom of hull to bottom of keel or double this size (mirror with hull), Am I right.??.. Where can I find a sample of a calculation of lift and drag of a keel, done by "hand" Regards |
| You can mirror it, OK. Does that help? |
| If I use the whole span inclduing the mirror, the results get a lot better, but i'm not sure if they are right.... Below are the results (and data used), and the lift is 3 times larger than using only the span of the keel below the hull.... Tk 3,4 Chord Top C1 1,7 Chord Bottom C2 1,25 Sweep Angle 21 AR keel 2,305084746 Main Chord Keel 1,475 Taper Ratio λ 0,735294118 Area Keel 5,015 CL 2d foil 0,11 α degrees keel 5 CL Keel 0,294488189 CDI 0,011975647 Drag 355,8513674 Lift 8750,593853 Thanxs |
| Any help any one can give mi a hint? |
| Scud or Warwick 24 - Wooden boat with stainless steel and aluminum lift keel ! | boony | Boatbuilding | 3 | 06-08-2006 10:01 PM |
| Stainless steel lift keel and aluminium case | boony | Boatbuilding | 4 | 06-03-2006 07:27 AM |
| canting keels: how are they displaced from side to side? | Thaddeus | Boat Design | 5 | 10-02-2005 04:22 PM |
| ajustable lift keel | OrionsSword | Sailboats | 10 | 01-03-2005 03:25 PM |
| side by side centerboards? | Ian | Boat Design | 8 | 01-02-2005 08:24 PM |
