Hi Guys,
I'm working on a Pearson Triton, which has a rudder hung just off of the keel. I'm also at that point where I know just enough to be a menace to society, and not quite enough to understand whats going on with them.
I'm looking for any tips and tricks to reduce the drag of this rudder. Currently it is a non tapered barn door, cut with a rounded shape on the back. I would like to build a "Constellation" (not quite sure why they are called that) with the squared profile, and glass in the prop-aperture.
The original rudder:
Albergs 2nd set of line drawings, though I don't believe Pearson ever used the rudder design in production.
Are there any guidelines as far as the gap between the top of the rudder and the bottom of the hull, and the gap between the rudder post and the semi-circular channel in the aft end of the keel? I'd like to spend the time and get whatever drag reduction is possible by working through the details!
I haven't found scaled plans that include this new rudder design, so I can only assume that folks who build them give a rough eyeball to what looks right. Do you guys have recommendations for books or computer programs that will spit out formulas that list the ratios for the surface area required to turn a boat this size?
I've been reading about endplates a little bit, and notice that folks try to keep the bottom of the boat directly above the rudder as close to the rudder as possible. Is there a benefit in making this flat surface wider so it acts as an endplate at times when the tiller isn't lined up perfectly with the keel? Pylasteki experiences some weatherhelm, and I'm wondering if the increased efficiency would reduce the effort required to hold the tiller, or even let it stay closer to centerline while sailing!
Is there a benefit to having a rudder that is neutrally buoyant, or is it alright if I build one a bit heavier? Intuitively it makes sense to me that a heavy rudder would ease the pressure on the tiller, as when healed your putting the tiller to weather or the high side... so the rudder is going down. I'm thinking that for the amount of weight added to the rudder (to a point) would reduce the pressure required to hold the tiller towards you. Do I have this all wrong?
Any thoughts on the width of the blade? I'm thinking that when the rudder is inline with the keel it would be best for it to taper from the width of the keel down to the 1/4 inch wide square'd tip. I have found it exceedingly difficult to find any information about keel hung rudders! Every paper I have found discusses spade rudders hanging on their own! Does a skinny blade living in the lee of a keel have less drag than one that tapers down smoothly? Sort of like when I draft a truck on my bicycle?
Thanks for your help guys!
Zach
Zach
