Old 09-06-2005, 10:13 AM
Phosphor Phosphor is offline
Rep: 11 Posts: 31
Keel edge
Hello.
My dad and I sail a 24' Bristol, made back in '69. It has a very snub-nosed bow, and that shape is carried down into the keel.
Also, it doesn't point very well into the wind, leaving an arc of around 105 degrees that we must tack through sailing close-hauled. I think the two are related but I am not sure...
One solution I was thinking of, is what if we reshaped the leading edge of the keel and the bow a little so that it bit more into the water? I'm thinking of moving more towards the shape of a J 24's fin keel edge, but I won't be able to get it as fine. Would this help our pointing situation?
Any advice would be much appreciated. Thanks!
I need a new signature.
Old 09-06-2005, 11:23 AM
Skippy Skippy is offline
Rep: 12 Posts: 568
The blunt bow is a reasonable suspect for poor pointing, but the keel is probably not, except for the overall long, shallow dimensions. The keel should have a smooth airfoil shape, whereas a finer V shape is good near the surface. Adding to the bow will increase weather helm, which may be okay depending on how much there is already, and will increase the waterline and make the bow finer overall, all of which helps to bring the speed up. One problem the longer bow might create is broaching issues running downwind in a healthy breeze. Then your weather helm will be a liability if the boat yaws and the bow starts digging in.
Old 09-06-2005, 11:44 AM
Rep: 11 Posts: 31
I completely forgot to think about weather helm. Oops. The weather helm is definitely not weak, but a tad on the strong side. How fine of a point should I go? Is it possible to meat a nice medium?
Old 09-06-2005, 12:54 PM
Rep: 12 Posts: 568
You'll want to consult with a professional NA for precise numbers. Bristols seem to be very well designed cruisers, so rather than "fixing" it, you might also want to consider trading to another design that better suits your needs. A lot of cruisers have heavily cut-away bows for downwind stability, as opposed to racing designs with plumb bows and square forefoots (forefeet?) for pointing at the expense of rough-weather safety.
Old 09-06-2005, 02:10 PM
Rep: 11 Posts: 31
Sounds good. I was just trying to get a primary feel for it. I'm not planning on taking any action until I consult someone for it. Ya know? Don't want to screw up a boat or a boat's safety just for performance. Thanks again.
Old 09-06-2005, 03:26 PM
Rep: 1623 Posts: 1,483
As another point, a tacking angle of 105 degrees across the true wind for the shallow full keel that she has is not all that bad. Have you moved the jib sheeting angle in yet and have got a really, really flat main? Both will do more for tacking angle than than expensive keel work.
Lifting Keel JHuberman Boat Design 19 06-26-2007 03:11 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
Long cruising keel foil shapes MikeJohns Boat Design 30 11-14-2004 02:35 PM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 10:54 AM
