Old 11-08-2005, 08:31 AM
fcfc fcfc is online now
Rep: 333 Posts: 677
Keel / centerboard area ?
Just a small question / verification.
For such boats (http://users.win.be/ws102917/microclass/rules/fig1.gif , www.microclass.org ).
18 ft loa (5.5m), 3 ft 7 in (1.1m) max draft , sail area 200 sqft. (18.5 mē)
The keel/CB area should be around 200 * 3.5% = 7 sqft. (.65 mē)
3.5% comes from principle of yacht design.
Kell span = 3ft 7 - 10 in (canoe draft) = 2 ft 9 in (85 cm)
Mean chord = 7 / 2ft9 = 2 ft 6 in (76 cm)
That should give an AR about 1.1.
Is the assumption of 3.5% incorrect, or is the draft very limitative for this class ?
Or any other thing I missed ?
(Even with 140 sqst sail (SAD = 20) , I dont get more than AR 1.5).
Old 11-08-2005, 06:22 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
Transverse pressure on sails = righting moment / heeling arm. If we assume windage on hull topsides and lift generated by hull underwater are equal, then transverse pressure on foils (keel + rudder), aka lift, = transverse pressure on sails. Lift is speed dependent, so the boat will make more leeway before it gets to full speed, and less once you have it churning along nice.
Estimate the wind speed, the resulting boat speed (the churning along nice one), the heel angle, and the righting moment at that heel angle. Then use the lifting line formula to solve for leeway angle. You want it to be 2.5 to 3 degrees. With 1.5 to 2 degrees of weather helm, your rudder should be operating at an avr. angle of incidence of about 4.5 degrees.
Faster boats and boats with higher aspect ratio keels generally require less foil area, and visa versa.
Details on drop and swing keel mik lenoir Sailboats 3 11-10-2005 07:03 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 12:00 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 10:54 AM
