Old 03-09-2006, 01:36 PM
MarioCoccon MarioCoccon is offline
Rep: 10 Posts: 101
Keel bolts in a 27 please enter!!!!!!!!!
Hi friends, My newport 27 1971 have the keel bolts a little corroted. I dont know if put more like the last owner of my Columbia 39 do, or just remove the older ones and replaced. What kind of bolts or screws are they and where I can find them. If some there with this kind of problem or good ideas??. I want to do this before put the boat on the water. Thanks
Old 03-11-2006, 10:35 PM
Rep: 505 Posts: 1,658
put new ones in they are inexpensive,and will give you peace of mind ,,,,dont forget to cauke them ,and check your zinks,
Old 03-11-2006, 10:55 PM
you can get bronse or stainless steel, you can buy stock from just about any hardware store,good stainless is not magnetic , check with a good magnet.
Old 03-23-2006, 01:13 PM
Rep: 10 Posts: 101
Hi and thanks, what will be the comment of put new ones beside the original ones. Thanks.
Old 03-23-2006, 05:38 PM
new ones are even better ,,,,good luck .
Old 03-24-2006, 07:51 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Keel bolts in a 27 please enter !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Do as Longliner says - replace them all. If the old ones have sentimental value, then use them as ballast. Otherwise, chuck 'em.
Keel bolts Brian Fredrik Sailboats 3 03-10-2006 01:08 PM
sugested materials sealing washer for keel bolts alice_ralphs Boatbuilding 2 04-12-2005 06:13 AM
Keel Bolts Willallison Sailboats 6 03-13-2005 04:22 PM
Rusty Keel Bolts gdshea Open Discussion: All Things Boats & Boating 8 08-13-2004 10:03 PM
Matrials for Keel Bolts/Nuts C3PU Materials 4 07-21-2004 11:16 PM
