Old 08-04-2007, 04:09 PM
panthablue panthablue is offline
Rep: 10 Posts: 17
Keel bolts
Last winter I went to the London Boat Show. I was looking over one of the boats there and got into discussion with the sales guy, and somehow I was allowed to look under the floorboards in main cabin.
When I looked, I was rather surprised to discover that the keel was held on with traditional keel bolts.
Could someone tell me is this normal these days?
I sail a steel boat, and the keel is nicely welded on thank you, and I haven't sailed anything else for about 20 years. I've never given it much thaught, but recently I got into discussion with some sailing friends and the subject came up.
I'm rather surprised that the world hasn't moved forward from this basic weak design, particularly as keels seem to be getting longer, with heavier weights hanging on the end.
Could anyone comment on this?
Old 08-04-2007, 05:39 PM
Previous Member
Rep: 0 Posts: 0
no it's common and the only way on all but metal boats, allthough I think some crappy boats once moulded a keel with hull, so all you massive run builders still use studs cast in, Bit of a misnomer (keel bolt) when in actual fact they are really studs, and often only cad plated steel, we have had forums here on this, so you should maybe search, keel bolts
what stuns me, is , why on earth you should NOT be allowed to pul any boat to bits to poke into any corner, its the builders obligation to show all
Old 08-04-2007, 07:21 PM
Previous Member
Rep: 0 Posts: 0
The Custom 30 fibreglass yacht built in Perth in the 70s had a deep keel that was moulded during the initial layup. My understanding is that molten lead was poured into the keel after it had cured.
At least one boat I know of had keel delamination problems in the hot zone after about 10 years. I do not know if this was a common problem. I have no idea if there was any effort to keep the fibreglass cool during the cooling phase.
Most of the fibreglass keel boats I know of have bolt-on keels. I have heard or read of leadshot being used by just pouring into resin inside a moulded keel.
Rick W.
Old 08-06-2007, 05:15 PM
Rep: 10 Posts: 17
This all sounds a bit depressing. Modern sailing boats have loads of technology stuffed into them, from hull shape, to sails, to electronics. It seems unbelievable that such a basic item has not been developed.
Anyway, just to prove I'm a closet nurd/designer, I couldn't resist having a go at improving this. See attached
Old 08-06-2007, 07:53 PM
raw raw is offline
Rep: 59 Posts: 133
Looks like you have solved a simple problem with a complex solution.........
From what I can see:
a) your solution does the same thing
b) is more complicated
c)will be more expensive
d)is less adjustable to curve in the hull or imperfections
e)relies on grub screws to absorb the entire load over a very small area of metal. They will eventually create some indentation, and therefore slack in the system. Do not underestimate the loads involved. Loads on keel boats will be several times the magnitude of the keel weight itself due to moment/coupling effects.
The simplest solution is often the best.....
Old 08-07-2007, 01:57 PM
Rep: 10 Posts: 17
Don't hold back RAW, just say what you think.
Old 08-07-2007, 07:56 PM
raw raw is offline
Rep: 59 Posts: 133
I thought I did
Old 08-07-2007, 08:02 PM
Previous Member
Rep: 0 Posts: 0
Pantha, I thought same, I think though your talents are wasted doodling with these things, now I could find you a job guiding me thru dwg maze, cept you would not get paid, but you would benefit from my wit, kindness, even tempered approach, ferget plastic boats, join us men)
Old 08-07-2007, 11:27 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Pantha,
Your keel attachment is different and original, but did not appear (unless there is more to it than I could see in the sketch) to offer any significant advantage over well set keel bolts/studs. I think the stresses would be concentrated in the attachment area in the same way. The deep rods would have far more strength than conventional keel studs, but I'm not aware of keel studs failing deep inside the keel.
I admire your thinking, but I don't think your solution is a big advance (yet). It's good to think about those things, but, in this case, it's somewhat like through bolting chainplates and cleats with backing plates. Simple, low tech solution ... but it works.
Your asking "why no changes" is great thinking, though.
Don't take lazeyjack up on his offer. Besides no pay, you'll be forced to listen to countless sea stories and endless lectures on the superiority of Russian ... everything. (He's right about the wit and kindness, though. He's a good guy ... for a boring old Ozzie)
Best,
Charlie
Old 08-08-2007, 12:11 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by charmc;
Pantha,
Get it Right Charles, I am not an Aussie, , bye the way, did you see we planted our flag down there, in the deep> oh and MIG still holds record for fastest and best fighter jet, , )
Old 08-08-2007, 12:20 AM
What's this "we" stuff, Stu?
Best,
Charlie
Old 08-08-2007, 12:28 AM
Previous Member
Rep: 0 Posts: 0
I jumped ship, chucked away my Eu and NZ, passports and took up with old Pute,
Actually my heart bleeds for my Ru friends, the towns, like Moscow St Pete Vladimir and the tourist places are ok, but the rest is in ruins, they work so hard, I try to really understand by mixing, , I could not mix in the South , Louisiana, New Mex, Alabama, nuff said, On dangerous ground here
Jus joking abt passports
big smile BXB, stocks went up 11% today, I have some,
now what was the good oil on the keel fixing?
Need Beneteau 30 1985 keel bolts!!!!!! MarioCoccon Sailboats 4 08-27-2006 12:17 PM
Keel bolts in a 27 please enter!!!!!!!!! MarioCoccon Sailboats 5 03-24-2006 07:51 AM
Keel bolts Brian Fredrik Sailboats 3 03-10-2006 01:08 PM
Keel Bolts Willallison Sailboats 6 03-13-2005 04:22 PM
Rusty Keel Bolts gdshea Open Discussion: All Things Boats & Boating 8 08-13-2004 10:03 PM
