Old 09-23-2007, 02:28 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
Keel Bolt inspection / replacement
I have a Beneteau Idylle 11.5 built in France. Has anyone had any experience, or knowledge of the method of Keel bolt fastening used? Were they cast in place in the keel, or tapped through the bilge? I have written Beneteau, but haven't received an answer yet.
The nuts (or heads) and washers are badly rusted and I want to pull one or two to inspect the bolts, but I don't know what method was used and I don't want to shear the bolt if it was cast in place or through bolted to the bottom of the keel. If they are simply tapped from above could you let me know the size of the bolt I should expect?
What method of repair have you had the most success with? Replacement or adding new bolts? If the answer is to add new bolts can you direct me to a web site, or book, that will instruct me in the correct method of determining the size of the bolt to use and best installation method?
Keel bolt inspection Mychael Sailboats 4 09-13-2007 03:13 AM
Clinker keel bolt replacement paulmuzzer Wooden Boat Building and Restoration 1 06-15-2007 03:34 AM
materials used for keel bolt washers chrisbeale Materials 4 05-22-2007 06:04 PM
keel bolt torque specification sens Sailboats 6 09-21-2005 03:41 AM
sealing washer for a keel bolt glynn Materials 3 05-31-2005 12:11 PM
