Old 03-11-2005, 10:41 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 312
keel alloy mechanical properties?
OK sailboat experts out there,
What sort of mechanical properties are used in keel alloy analysis and design? I'm specifically curious about Emodulus, allowable stress, yield stress, ultimate strength for typical keel lead alloys, ie. lead-anitmony 3%.
much appreciate if anyone could forward those numbers to me.
Old 03-14-2005, 06:56 AM
Naval Architect
Rep: 73 Posts: 312
No takers? Someone in boatdesign land must have that info...
Old 03-14-2005, 10:51 AM
Skippy Skippy is offline
Rep: 12 Posts: 568
I have a couple inklings on this subject, but that's about it. One guy building a back yard boat believes the lead should be alloyed with 4% antimony for hardness. Apparently X-ray shielding doesn't have the antimony, but automotive wheel weights do.
Other than that, I would only want the structural materials to be very very strong.
Old 03-15-2005, 10:56 AM
Ssor Ssor is offline
Rep: 10 Posts: 174
Lead keels are usually such thick sections that the only concern anyone would have is the ability to hold the cast-in bolts. If the lead is exposed, then grounding on rocks gouges the lead but lead is not used for its mechanical strength. That's why you never see lead center boards, usually wood weighted with lead, or steel or bronze center boards.
Even alloys of lead are only relatively "hard". Zinc is much harder and you could chisel marks in any lead alloy with aluminum.
Old 03-15-2005, 11:25 AM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Lead with 3% antimony has a Tensil Strength of 4700psi, an elongation of 16%, and Brinnel Hardness of 9.1. 5% antimony TS= 6360psi, elongation 29%, and hardness of 11.
Old 03-15-2005, 12:19 PM
Naval Architect
Rep: 73 Posts: 312
Gracias,
Any numbers for Emodulus or Yield (0.2% offset I guess)?
Old 03-15-2005, 03:05 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
If you are not satisfied with your keel(weight) then take low radiance Uranium,
whatever the chemical composition of lead, you are not going to better it.
Old 03-15-2005, 04:10 PM
Rep: 10 Posts: 174
Kinda hard to come by depleted uranium though.
Old 03-16-2005, 06:18 AM
Rep: 700 Posts: 3,208
A visit to Bagdad should solve the Depleted Uranium supply source problem.
Scrap lead has been used for centuries , still the cheapest option is steel , although it needs to be a bit wider to have same CG. location.
Steel is probably the strongest to run aground with,
FAST FRED
Old 03-16-2005, 06:24 AM
Naval Architect
Rep: 73 Posts: 312
OK, thanks for the clever quips-
Any #s for Emodulus or yield?
Old 03-16-2005, 01:10 PM
Rep: 140 Posts: 560
E= 2030 ksi for pure lead
Tensil Yield Str. 1160 psi ( 2% offset)
Old 03-16-2005, 02:24 PM
Naval Architect
Rep: 73 Posts: 312
Thanks mon
Lifting Keel JHuberman Boat Design 19 06-26-2007 03:11 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 10:54 AM
Aluminum masts: mechanical properties Gades Boat Design 3 09-09-2002 10:07 PM
