Closed Thread
  #391
Old 02-10-2005, 01:54 AM
frankofile frankofile is offline
Rep: 10 Posts: 91
Originally Posted by mighetto
What an informative post.
Not surprised you think so.
  #392
Old 02-10-2005, 02:41 AM
Anarchist Anarchist is offline
Rep: 10 Posts: 4
South Africa was rumored to be producing a Mac26x knockoff. Can you confirm? In my sailing for idiots book no one is arguing here. Constructive critizism and funning and some sparks of insight. Please join in.
The above is the rudder for an I-14. The owners association decided not to go like the moths you are discussing elsewhere have, though that is also possible for an I-14. Think of the rudder as if it were an outboard. The same horozontal fins you find on ski boat outboards are evident on the I-14 fin pictured. The manufacturer doesn't like this kind of thing on Mac26x boats. But owners have run them that way. Planing under sail at lower speeds would be the result (assuming the prop had been removed). The lifting and tilting hydrolics are already part of the boat.
Do Stars plane? Stars will be racing PHRF-NW boats in the same events this season. The results of the races will be noteworthy.
Hey fuckwit Frank,
This rudder system for the I14 does not induce plaining. The boat will be already plaining with its light weight plaining hull travelling at speed. These foils are used to change the pitch of the boat into a more nose up possition when pushing hard and are only used when the crew is as far back as possible and still needs to get the bow higher. If used in light winds it will cause drag and thus the boat will be slower.... The rudder case can be pivoted back ie bottom of the rudder moves more aft to change the angle off attack. Wen you turn up wind you pull the line controling rudder pitch and bring the rudder forward again.
The foils on the rudder are ALLOT bigger than those found on outboards. Also a yacht is too heavy for this system to lift the bow. All it will cause is drag......... And if you think any different you are a complete idiot....... ohh thats right we have already established that
  #393
Old 02-10-2005, 03:10 AM
mistral mistral is offline
Rep: 22 Posts: 154
AGAIN, Frankie, YOU DID IT AGAIN!!!!
they're not the same roizontal fins, that's YOUR problem, and most of all of MAC26, ski boats and Moths have SLIGHTLY different weight to lift, do you konw what "weight" means Frankie????
i guess no.....
Mistral
  #394
Old 02-10-2005, 04:32 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
I have had some problems with attachments, but if everything went OK, you should be seeing a picture of a planing Mac26x. What you don't see is the rig. I guess the owner realized that the Mac is not a sailboat and decided to get rid of it...
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
  #395
Old 02-10-2005, 06:29 AM
Rep: 22 Posts: 154
somenone 's beginning to use this boat for what is suited to do: motoring!!!
next step: throw away those unuseful rudders, remove those ugly stanchions and lifelines and palace a modern stainless pulpit, get a good flying bridge and enjoy your motorboat!!!
Mistral
  #396
Old 02-10-2005, 12:16 PM
mighetto's Avatar
mighetto mighetto is offline
Rep: -6 Posts: 676
Originally Posted by Anarchist
Hey fuckwit Frank,
This rudder system for the I14 does not induce plaining. The boat will be already plaining with its light weight plaining hull travelling at speed. These foils are used to change the pitch of the boat into a more nose up possition when pushing hard and are only used when the crew is as far back as possible and still needs to get the bow higher. If used in light winds it will cause drag and thus the boat will be slower.... The rudder case can be pivoted back ie bottom of the rudder moves more aft to change the angle off attack. When you turn up wind you pull the line controling rudder pitch and bring the rudder forward again.
A infamous idiot - eh? We are literally in fog this morning.
The I-14 rudder pictured yesterday, complements of Richmond Point Yacht Club, as is the Murrelet II, is mostly used apparently in keeping the bow of the boat from a nose dive. You are correct. It is not the primary source of lift. The horizontal foils are trimmed by pushing down the cap lever on top of the rudder at the appropriate time. We are fortunate in the Olympia Washington area in that the Columbia river is but a few hours away. The Gorge on the Columbia is believed by some to be the most active sailing area in the world even overtaking the sailing areas in your country. I do not buy into that but I do suspect it is the most active in the US.
The above is the Tasar, which you will find also on the Columbia River. However, these are from the Worlds when they were held in the Straits of Juan DeFuca. (40 foot waves caused a semester-at-sea vessel to return to port there last week.) The Tasar is the dinghy I believe most resembles the Mac26x in planing mode. If you buy into the notion that Tasars plane then you should recognized that the Mac26x does as well. It is not the kind of jump to warp speed thing that the Melges and I-14 folks get. The planing mode is entered in a less dramatic way and your crew may not notice that you have gotten to this third mode of sailing. But you will see double digits on your GPS.
The pioneer owners of the Mac26x apparently experimented with horosontal foils on the outboards which are lifted and dropped by hydrolics.
The above vessel followed those pioneers, in spite of the manufacturer adding a special safety warning to the owners manuals. The engine manufacture did not consider the small horosontals an issue. Plus, many X owners had already adopted the long used by prior model owners of blowing out the ballast with raft inflators so that you were confident it was empty. This is what Macgregor Yachts says:
"Do not install a lifting hydrofoil on the cavitation plate of the outboard motor. These are airfoil shaped wings, offered in various sizes and shapes. Their purpose is to provide lift at the stern of the boat. This raises the stern and forces the bow down, allowing the boat to get up on a plane more quickly. If they do keep the boat level when coming up on a plane, the ballast tank may not drain completely when the boat is underway. You may think you have an empty tank, but you may not. These hydrofoils create another problem when the boat turns or leans sideways while underway. The lift that they provide goes straight up the centerline of the outboard motor, adding a strong force to promote further leaning or capsize. These devices can exert a large amount of force; enough to snap off the cavitation plate that is cast as part of the drive shaft housing. Avoid them."
The Mac26x boat plains at speed undersail without lifting hydrofoils on a deployed outboard. The early model rudder brackets were substantially reinforced by 1999 because these rudders are lifting foils and do that job. You can see the stainless steel brackets on the photo of the Wind. Well kind of. One day I will find a pre 1997 Mac26x with the first generation brackets. They were reinforced likely owing to the mechanics of planing under sail. The rudders are not deployed when motoring at speed. Under sail, these foils do gradually change the pitch of the boat into a more nose up possition when pushing hard. You are instructed to move the crew is as far back as possible to get the bow higher. A high bow reduces the length at waterline which decreases the displacement hull speed meaning that you are into forced mode at a lower speed than would be indicated by math. By moving the crew forward, the Mac26x crests her bow wake and is plaining. Sustained planing mode is not at all difficult.
In light winds, the outboard hydralics would have the lower unit out of the water entirely so any lifting hydrofoil would not will cause drag and thus make boat slower.... I do see your point. On the I-14 you state The rudder case can be pivoted back ie bottom of the rudder moves more aft to change the angle off attack. When you turn up wind you pull the line controling rudder pitch and bring the rudder forward again. Outboard engin lower unit lifting hydrofoils do not have that level of tuning. But I think there is possibility for assisted planing without turning the engine on. When the X is in forced mode, instead of moving crew forward you might be able to adjust the bow attitude and crest the bow wave to reach plane. Perhaps you are correct and the horozontal fins need to be larger. This is just fun chat. I do not intend to do a modification like this. It appears that MacGregor Yacts is concerned more about the transition from ballasted to unballasted state than other issues. What do you think?
  #397
Old 02-10-2005, 12:32 PM
Rep: 22 Posts: 154
i may seem boring, but i'm still waiting for a MAC26 planing picture, i mean with engine off....
This thread is becoming really boring :-(((
Mistral
  #398
Old 02-10-2005, 12:49 PM
Rep: 22 Posts: 154
Frankie, do you really believe what you've just written????????
Mistral
  #399
Old 02-10-2005, 12:51 PM
mighetto's Avatar
Rep: -6 Posts: 676
Mistral
OK, Mistral. I have not had much luck with my photos. So here is a photo of the wake that I believed proof of planing under sail.
So let it rip. I have been here before - thats 3 knots you idiot - etc etc. Only it was 9.5 to 12 MPH sustained for over 20 minutes off Shilshole. We were passing two masted schooners of 50 foot with all cloth flying. The wake is powerboat like - or catamaran like. Heel over 11 degrees. True wind from behind. I have also tried
and this photo which I thought very convicing
but, these photos, which I believed proof, mean nothing to those who define planing. So I stopped arguing it. It is true that the mac26x does double digits, even 17 MPH and that the manufacturer claims the X to be its planing sailboat model and the M to be a surfing model. The keel boat trained have little chance of reaching those speeds but the dinghy trained and those new to the sport can get there easy by putting an intermediate point reef into the main, and sailing on a high normal wind day - say 12 to 17mph with full water ballast. Fire away. We are all vulnerable in our rears. Mine is now exposed. Note the bracket on the last photo that holds the lifting rudder foil.
  #400
Old 02-10-2005, 12:58 PM
pkoken's Avatar
pkoken pkoken is offline
S/V Samadhi V
Rep: 43 Posts: 98
Frank, I don't think you have ever been aboard a planing sailboat- Those pictures are from a 2-4 knot displacement cruise, nothing more.
Regards, Phil
S/V Samadhi V
http://www.samadhiv.org/
Cruising Hawaii
  #401
Old 02-10-2005, 01:03 PM
Rep: 10 Posts: 91
Ha ha ha! I knew we'd get here eventually. Frankie actually believes those pictures are of a planing wake. He has absolutely no idea what planing is, even after seeing the great pictures pkoken posted yesterday.
"Subtle transition" [Sorry, actual quote is "The planing mode is entered in a less dramatic way and your crew may not notice ..."]... as in "never happened" you dolt.
  #402
Old 02-10-2005, 01:20 PM
mighetto's Avatar
Rep: -6 Posts: 676
I am struggling with it. Of all the discussion on all the forums I have been involved with involving my ride - the planing capabilities of the vessel have been the most controversial.
Certainly the boat planes under motor power. The manufacturer wants you to protect the rudders while motoring by lifting them when the boat is motoring above 7 MPH. That is right at the thoretical max hull speed for a displacement hull of 22 feet (7.22 MPH). I estimate that when crew are sitting aft that 22 feet is about what is presented to the water. However, possibly all of us have motored with the rudders down (operator error) at high speed and haven't ripped off the rudder fins.
When I first drafted the statement Under sail, these foils do gradually change the pitch of the boat into a more nose up possition when pushing hard. I was thinking of one fin and two fin operation. On a 11 to 15 degree heel, I think I feel the boat lift under me when I drop the second rudder, which brings the nose down. You are instructed to lift a rudder when going down wind which would lift the bow then (right?). The flat portion of the hull in the rear also is contributing to lift when you get speed. Perhapse the lift isn't as great as the boat you are thinking of and most of the lift comes from hull characteristics. But the rudders are definately lifting foils.
One of the definitions of planing that I picked up was that if the wind indicator points forward of midship on a downwind run then you are planing. So I took this photo when my notions were being ridiculed a few years back.
What I believe is that Roger MacGregor put his career reputation on the line with the Mac26x model. He claims the boat is revolutionary and does 17 MPH under sail. I have no reputation to loose on this. So I can at least speak and try to understand and match that performance. The moment I admitted to being a former power boater, I lost credibility with a good number of "sailors". The same thing happens with those who admit to being multi-hullers so I just do not take it seriously anymore. What do you think? Fog is lifting? OK, rip away. I will be unavalable for several days and unable to respond. So have fun.
  #403
Old 02-10-2005, 01:35 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Thanks, Frankie - I needed a good laugh. However, you now owe me a keyboard, as this one is drowned
Steve
  #404
Old 02-10-2005, 02:44 PM
Reemul Reemul is offline
Rep: 10 Posts: 39
Frank, That top picture sure looks like the South Sound (Dana Passage area) not Shilshoal area. Now the attached picture (by Sean Trew) was taken of my boat (S2 7.9) going downwind in 10-15kts of wind. We were sailing at 7kts overground against a .5 kt current in Dana Passage and were NOT planing. How do you feel this compares to your photo?
  #405
Old 02-10-2005, 11:11 PM
skinny boy skinny boy is offline
Registered
Rep: 10 Posts: 52
Planing in the Mac26x is like the slot effect, generations of sailors have all experienced it and know its there whether or not you can actually see it. The fact that Murrelet nevers planes in the presence of another boat that can attest to it merely means no one understands what conditions are right for it.
Afterall by the definition provided the Mac26x only qualifies as a non-planing boat unlike ULDBs. So we know the normal planing winds only exist around the Mac26x and others never see it because it doesn't exist in the rest of the world.
Closed Thread
Confused about Designing a Hull & "Principles of Yacht Design" Free Pirate Boat Design 8 03-10-2005 12:16 PM
