Old 04-29-2011, 08:50 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
Super Scow
There has been some discussion lately about scows and I couldn't find this thread so here it is. A canting keel scow surely allows the thing to be self righting but I wonder if just the minimum keel to right the boat was used with some form of on-deck movable ballast? And, of course I'd bet curved lifting foils would add speed...
Incredible Scow (from SA)-scow-pbs-3.jpg  Incredible Scow (from SA)-tantra-heli-big-ungava-scow-012.jpg  Incredible Scow (from SA)-curved-foil-scow-002.jpg
yes, it is a revolution
Old 11-03-2011, 10:44 PM
Daniel Noyes Daniel Noyes is offline
Rep: 32 Posts: 40
Interesting Doug any further word on this design?
The scow concept is at it's core a extremely low drag one, in displacement mode and in planeing mode, to generate lift with a curved foil will also generate drag
I'm not convinced that the drag of generating lift will be off set by a reduction in hull drag by lifting the hull out of the water... infact the scow uses it's long sailing-waterline length vs width when heeled to attain a high hull speed... if you start lifting the hull out of the water you rapidly reduce the lenght of the sailing-waterline but wont affect the width that much
I wonder if a curved foil might allow the scow to carry sail in stronger winds though and attain a higher top speeed
Old 11-04-2011, 06:58 AM
Doug Lord's Avatar
Flight Ready
I haven't heard anything more but I bet with the incredibly decisive victory in the Mini Transat by David Raison in the Mini Scow we'll be hearing at lot more about the type.
At least until Welbourns DSS mini gets going! Mini Ocean Racing Scow
rough sketch-curved foil on tunnel hulled scow. Won't do much for RM but would reduce wetted surface for sure.
Old 11-04-2011, 07:16 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Doug, the foil configuration you have sketched will move the vertical lift inwards, and thus will reduce the RM.
Old 11-04-2011, 09:16 AM
Doug Lord's Avatar
Flight Ready
Slavi, you're right. The curved foils on small cats do the exact same thing and they have deterimined that the reduction in RM is worth the increase in vertical lift for a net reduction in drag and increase in speed.
picture: NACRA 20 curved foils:
New Zealand Scow dskira Sailboats 130 07-17-2011 09:43 PM
Incredible design, the oviparouswoolmilkpig ? apex1 Boat Design 88 09-24-2010 07:53 PM
Incredible prop shaft driven bilge pump - Amazing volume pumped yachtwork Marketplace 1 03-28-2010 11:57 AM
Solution Sailing Scow TheJoe Boat Design 8 09-17-2009 01:06 PM
8 mt scow bushman Boat Design 5 09-05-2008 06:08 PM
