| IMOCA 60 lines plan For my final year project at Strathclyde University I am hoping carry out model tests on an Open 60 with an interceptor system fitted. Then to encorperate the resistance information into a VPP with the aim of generating correction factors for the use of the system. Does anyone have or know how to access a lines plan for an Open 60? |
| Chris, are you doing your work on a transom mounted interceptor or on the "Midship Interceptor" by Jurgen Sass? Midship interceptor Good Luck!
__________________ yes, it is a revolution ---"So (yet) another new world begins." Andrew Hurst, editor of Seahorse magazine, August,2011 |
| Doug thanks for the reply, I am looking at transom mounted interceptors, chris |
This is not to be confused with the Farr boat that had the articulating hull section aft. Check Seahorse magazine for the details, then consult with the designer to see if there is any possibility to use his linesplan. I doubt you will get it, but it doesn't hurt to ask. |
| Paul, it was the seahorse magazine I got the idea from! Originally I was hoping to run tests comparing the performance of the articulating hull section (or planing board) and the interceptor on the same model. Although due to a number of factors, including limited tank time I have opted to consider the interceptor alone. I have contacted some of the designers already but not had any luck. Will keep trying with others though. Thanks for your reply Chris |
| Try Simon Rogers at Rogers Yacht Design. Artemis has interceptors and he is a nice fella. |
| The HISWA Symposium in 2000 had a paper by Keuining titled "The Influence of the Bowshape on the performance of a sailing yacht" had a resistance analysis of an open 60 with both full and fine forward sections. You might want to see if that info is available from Keuning - it would be a good start for comparison since there is already tank test data available as a baseline. |
| Lines Plan | builtinpieces | Boat Design | 3 | 10-28-2009 01:14 PM |
| KB from lines plan | ivansalasj | Boat Design | 3 | 03-25-2005 07:34 AM |
| Lines plan from Rhino | AndyRed3D | Software | 14 | 08-04-2004 12:05 PM |
| lines plan development | fede | Boat Design | 4 | 11-23-2003 08:30 PM |
| lines plan for cal 2-29 | trimhorn | Boat Design | 0 | 06-20-2002 03:45 PM |
