| The Ideal 18ft Daysailer Hello to all, I'd like to have the input from all those interested about the following parameters: Sailpan Fin keel or daggerboard Crew number The goal is to design a 18 footer for daysailing and the eventual handicap regatta. Thanks to all
__________________ "Between the rocky shore and the rising tide, is the crab that gets screwed" |
| Trailer-able, it should be a dagger board, ballasted, the boat should be self righting, Crew? Any 18 will be single handed capable, max 6 comfortable 4. Nice wide side decks to keep it dry in a knock down. Medium beam for good speed. Are you set on an 18? Cost of construction, a 20 won't be much more? Price seems to jump every 4' more than 2'! There are some nice 20' racing scows if you like the older look? I like the look of the scows! |
| BHOFM, Thanks for the input. And yes I'm bound to the 18' dimension. About the saiplan I was thinking a squarehead main, jib and assimetric spi/gennaker on a sprit. I want this baby to be mean and fast, a wet and thrilling ride.
What you describe with "mean and fast, a wet and thrilling ride" is just another hot rod racing boat. Buy a 18 foot skiff. ![]()
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| There are some self-righting keelboats that are daysailers AND wet and exciting-I don't see the two as mutually exclusive. This is a 21 footer seen on SA: |
| I'd like to see a bulb ballast on a deep foil, but set up to raise like a lifting keel for trailering purposes. An underbody cutout the body plan shape of the bulb would allow the entire keel/bulb to be brought flush with the bottom. This would be raised by halyard with tackle added. The reasoning is simple. Dealing with a very deep draft boat, not only is one spending for getting the boat in and out, but chances are the boat will (consequently) spend the whole season in one place. A new class should be easy to transport in order to attend regattas at different locations. Slightly more money up front, but far cheaper to own long term. Alan |
| Sounds pretty much like this; http://www.seascape18.com/prvastran.htm Or maybe the i550 Alan, I’m not sure why you would need a cutout in the hull for the bulb, in this size of boat your probably looking at 100-150kg, this is physically small enough that the rear cradle on the trailer just has a cutout in the middle for the bulb, in fact where I sail many of the boats will trailer launch and motor out into the harbor before fully lowering their keels. I’ve got a 23ft sport boat that I actually launch off a beach trolley like a dingy and it has an 85kg bulb. As for raising and lowering I’ve got a 4:1 tackle that can either be connected to a trap wire or the end of a windsurfer boom the straddles the keel. In fact in NZ/Oz almost all of the sport boats (and anything under 25ft) are usually trailer launched |
In terms of self righting I kind of get the impression that some people are actually implying ‘not capsizing’ ie laying over, rounding up and popping up into the wind with the sails flapping, this is definitely not the case with some of the lighter faster sport boats. As for quoting a design as self righting it really depends on what rule it is built to, the NZ SB rule is probably one of the less restrictive of all and from memory (maybe wrong here) it is something like 10% of the bulb mass at the hounds to hold the boat at 90deg, with this requirement its likely that the boat will not be AS self righting as people may expect, if you’ve got the kite up it will not self right and if you go past 90deg it may not either |
| Cheesy, how deep for a 150 kg bulb on an 18 ft boat? Like 2m? |
That said, it has a vertically retractable high aspect ratio keel with 230kg bulb on the tip. Max draft is 1.5m and retracted 0.4m draft
| 5.5 day sailer 5.5m x 2.25m, sketch rigged, freestanding wing masts, 21m2 SA, 120 kgs weight, water ballast 80 kgs. |
For your example I would think you could have much shorter with a more beam (only 1.2m in pic) and a smaller rig, see if you can find the specs on an Elliot 5.9, they will be pretty close to what you’re talking about as well |
| 18foot daysailers "as long as you’ve got enough keel area you’re pretty much trying to minimise the amount of ballast required to fit a rule (down here anyway) most of these types of boats are faster without the bulb at all." Interesting comment Cheesy, going against the fashionable grain - but I'm sure you are correct. Another shot of my 5.5m. The assembly towards the rear is for the canting rear "sketch" mast. |
If I wanted a 18' skiff I'd buy one, the idea of this thread is to gather opinions and insights for my own project, currently in its preliminary design stages. Everybody's contribution is valuable BTW Gary, what's a sketch rig? A crossover between a sloop and a ketch?
Since there are all sorts of sailing hot rods out there, and darn few sensible daysailers I thought you were aiming at that sort of a design. My error. I wish you the best. R
| Building an 18ft Flat Panel F.G. Sailboat | bill31416 | Fiberglass and Composite Boat Building | 4 | 04-25-2008 01:31 AM |
| Tja 17 to 18ft. hull mold wanted | tja | Boat Molds | 2 | 01-28-2007 09:44 PM |
| Customizing an 18ft fiberglass | svonmiller | Powerboats | 3 | 10-02-2006 09:20 PM |
| Need to build a 18ft Aluminum Boat | myles king | Boatbuilding | 1 | 06-24-2005 11:20 PM |
| building a 20' daysailer | hohnpm | Open Discussion: All Things Boats & Boating | 1 | 05-11-2003 10:40 AM |
