| Hydrolic steering Is it common for a 43' sailboat with hydrolic steering to require 6 turns lock to lock or do I have a problem? There is only one steering station. |
| You have a problem! Common is 2,5 max 3 turns from hard to hard. I assume your plunger pump is too small. Regards Richard |
| If there were always 6 turns the answer is in post #2. If the phenomenon is new, there may be air in the system due to a leak (slurping sound) or a faulty pump/ hydraulic motor.
Do you keep the pressure on a hard lock or does the system leak ? Last edited by LyndonJ : 05-03-2010 at 06:57 AM. Reason: outside pump only |
| I'm not familliar with the unit but the pump appears to be at the base of the wheel hub. There is a resevoir fill behind the wheel. Could this unit be rebuilt? or would it have to be replaced withn something larger. The lock to lock turns have been consistant and there is no further movement once the helm is hard over. |
| It is the difference in displacement between the pump at the wheel and the cylinder or plunger motor near the rudder which determines the ratio. Look for a type number and name on both of them: if it is a system from Vetus you can get information on their website. I asked in post #3 if this unit has behaved this way since day 1 (wrong combination) or if it is a new problem (defect).
The only solution is to replace the pump with a bigger model. As far as I remember "Vetus" provides a comparison table in his catalogue, where one can match the pump to the cylinder volume. Regards Richard |
If the arm is long the movement will be slow and very easy to turn the wheel !! If the arm is shortened then the rudder will turn quicker with less turns of the wheel but alsowill be harder to turn the wheel !!! Logical ? ![]() |
| What I more or less expect is that Captjj is not the first owner and fears he's recently bought himself a lemon. But I may be wrong and he only supplied minimal information, at least not enough for me to provide a clear answer.
| I hear what you are saying !Everyone has differant veiws and have differant priorities pictures dont lie so thats what we need to see what is actully there and how its set up and what is being used !. ![]() |
| If you put a larger displacement pump, it will have less turns and require more effort to steer.
__________________ Gonzo |
| Its actually adjustable on my boat
__________________ sv Libertalia |
| I would think it should be adjustable or just a matter of drilling a hole a little in the arm closer to the rudder shaft and that will have the same affect . as with all things dont get something without sacrificing something else . ![]() |
| Hydrolic steering | captjj | OnBoard Electronics & Controls | 2 | 07-07-2010 12:08 AM |
| Self steering with steering oars? | Alex.A | Boat Design | 8 | 04-25-2010 11:04 AM |
| Hydrolic System for Spud | internetturk | OnBoard Electronics & Controls | 2 | 08-30-2009 03:39 PM |
| self steering | bill broome | Multihulls | 35 | 12-07-2008 11:06 PM |
| Hydrolic tranny problem | IMSETFREE | Diesel Engines | 4 | 10-09-2006 02:49 AM |
