| Hydrodynamic Drag I am trying to do some physics coursework and i need a ball park figure for the hydrodynamic drag of a sailing boat at a known velocity. OR a formula for drag. It doesnt really matter what size of boat or yacht these figures are for. Many thanks ![]() |
| To help find Drag due to Skin friction figure Turbulent boundry layer drag is proportional to Flow Velocity^9/5 x Wetted area Laminar Boundry layer drag is proportional to Flow Velocity^3/2 x Wetted area Turbulence will always occur if ( Length x Velocity )/ Viscosity = > 10^6 There are many other components to Hydrodynamic Drag but if the hull is Large and the Speed is Low then Skin Friction is the largest contributor. |
| What i really need are some figures for the drag on a small dinghy or a formula. Those formulae, without the constants of proportionality arent much help. What i am trying to do is apply some simple physics to a boat and work out its maximum possible speed. What would be really helpful would be a simple formulae, which doesnt need to be very accurate, which will give me the drag of a boat relative to its velocity |
![]() Plus, for a displacement hull form, the "max" speed is relatively (dangerous word) well established. Flame wars notwithstanding..... Steve |
| Ok, but what are the constants of proportionality, roughly |
| Go to www.sailboat-technology.com. Under "Online Articles" you'll find a link to "The Bare Hull Resistance of the Delft Systematic Yacht Hull Series" by J.A. Keuning et al. (and a lot of other interesting stuff). The formulas are probably no good for dinghies, but at least you'll find out that the formulas aren't simple... Søren Flening |
| You can try the applet-based calcuator here: http://www.users.globalnet.co.uk/~fs...chts/index.htm Doing a little googing on "amateur yacht research" will raise of host of alternatives. |
| Tandem Keel...? | Lew Morris | Sailboats | 27 | 06-01-2007 04:18 PM |
| Some ideas | yipster | Projects & Proposals | 81 | 02-15-2006 01:32 AM |
| Pros and Cons of Transom Hung Rudders | Gone Ballistic | Sailboats | 19 | 09-19-2005 09:15 PM |
| How close to the wind can a boat sail? | tonyr | Sailboats | 13 | 06-13-2004 08:35 PM |
| formdrag | yipster | Boat Design | 7 | 02-22-2003 01:13 PM |
