Old 02-10-2010, 11:45 AM
PaiMei PaiMei is offline
Rep: 10 Posts: 7
Hydraulic lifting (telescope) keels?
Grüezi!
We are searching for an out-of-the-box solution for a hydraulic lifting keel where the lower part of the keel slides into the upper part, just like a telescope.
We have seen this system on Hanse 630, Nautor Swan and a boat called diamant3000.
The keel bomb is 1.100kg, total length of the fin is 1.2 meters.
Anyone knowing other boats that have this type of keel (which we just love because the interior stays untouched with this telescope type of keel and for us a reduction from 1,2 to 0,9meters would be fine.
Thanks for your help
PM
Old 02-10-2010, 12:15 PM
CDK's Avatar
CDK CDK is online now
retired engineer
Rep: 1425 Posts: 2,255
Is that really worth all the trouble and expense for just 30 cm.?
You need a hydraulic pump unit with reservoir, tubes through the keel, hoses and two expensive cylinders, stainless with scraper rings to protect the seals, flanged to the keel, pivoting at the keel bomb. An expensive gadget!
Old 02-10-2010, 12:17 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
The only full size yacht I am familiar with that has a keel like that is Maximus:
http://www.supermaxi.co.nz/
yes, it is a revolution
Old 02-10-2010, 01:06 PM
Rep: 10 Posts: 7
Unfortunately yes because our harbour entry is suffering from little water from time to time so we need to make sure that we can always leave and come back. Probably the same reason why they have it on the Hanse and on the Diamant3000.
BTW we need to reduce from 120 to 75cm......
Thanks again
Old 02-11-2010, 03:50 AM
CDK's Avatar
retired engineer
Is this what you have in mind?
Old 02-13-2010, 05:45 AM
Smyrre Smyrre is offline
The boats you describe above are very different in size. But if you look for a boat more or less in the size of the D3000, you could check out the new Clarc 33. She offers a lift keel with 1,85 - 1,10m and is trailerable with modern classic design - www.clarc-yachts.com
Old 02-13-2010, 05:58 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
How important is the interior in the keel area?? Somewhat cheaper hardware and easier engineering can be used if the lifting structure is lifted btw waterline and deck with the cost of lost space below deck..
engine lifting bertho Diesel Engines 5 09-17-2007 04:21 AM
Lifting Keel JHuberman Boat Design 19 06-26-2007 02:11 PM
Lifting a Deck steveo Fiberglass and Composite Boat Building 2 03-10-2005 08:18 AM
Lifting Keels Danidrac Boat Design 0 02-06-2005 12:16 PM
Lifting Lines DavidG Boat Design 9 01-01-2004 11:00 PM
