| Hydraulic Backstay Adjuster All hands, This question is a long shot... The hydraulic backstay adjuster on my Dufour 39 has given up the ghost, it leaks like a sieve. But other than that it appears to be in pretty good shape. The previous owner had it installed on the boat, and the only information he had on it's origin is that, "it came off of a sixty-five footer..." The only identifying marking on it is a logo on the face of the dial that looks like to back-to-back parenthesis marks. i.e., )( The fasteners are metric. Does this strike a familiar note with anyone? Not much to go on I realize... but worth $1,200, or so, if I can rebuild it. Thanks all, Lew Morris Port San Luis, California |
| Sounds like an old David Carne unit. Is it a Stainless Steel unit? Hopefully the leak is only an o-ring seal, anything else and you're out of luck. It isn't worth 1200 in any currency. |
| If you take it apart and remove the o-rings and seals, a hydraulic parts supplier should have what you need. Many parts are universal.
__________________ Gonzo |
| bosco It is stainless. The top end is machined aluminum, the lower end is stainless. The leak is a pain in the ass, my transom will attest to it! I fabricated a stainless "link" to replace it until the unit is repaired. Hopefully I can find what I need at the local hydraulic repair shop... of course the parts will probably have "John Deere" on them, but what the hell, as long as they work Any leads on David Carne? I will assume (always dangerous) that it is a low-volume production unit... the serial number is hand engraved on the tube. And you are correct, it isn't worth $1,200 in any currency, but that IS what a new Navtec lists at... .. . if I need to replace the old one. Thanks for the help Gents! Lew Morris |
| twenty minutes on the net ... David Carne it was. He e-mailed back this morning. Thanks for that extraordinary bit of observation! Lew |
| Hi Lew i am having the same hydraulic backstay issue. Can you please give me the contact for David Carne. James |
| Dear ''Guest'', Somebody of your calibre, who can identify a piece of equipment with such little info, and without even a photo, in my opinion deserves to be a permanent member. If i may, I would like to invite you to this forum on behalf of everybody here. |
| I have exactly the same problem with a David Carne backstay tensioner. Does this company still exist ? Is it possible to get parts, original or equivalent ? Many thanks for the informations |
Dave Carne -- Bill |
| Ultegra Your backstay adjuster is a Veretex. I literally pulled the label offof mine 5 minutes ago and was searching for info for my files. I can't find anything. I assume your boat is a French built boat as is mine. I had mine rebuilt a few years ago. I took it to a friends hydraulic shop. They changed a couple of O rings, I gave him a case of beer Nd itsbeen fine ever since. These thingsare very basic hydrLic rams and any decent shop can fix them easily. |
| Some Q on Stabilizers. | fcfc | Boat Design | 21 | 03-10-2005 05:47 PM |
| Gas driven hydraulic generators - regulations? | Gilmarine | Fiberglass and Composite Boat Building | 1 | 11-01-2004 02:45 PM |
| Backstay | Lew Morris | Sailboats | 6 | 06-30-2004 04:25 PM |
| Roach to backstay clearance | des | Sailboats | 1 | 06-30-2004 07:41 AM |
| backstay adjuster | regulus | Boat Design | 2 | 01-13-2004 03:07 AM |
